1 - Mill APL - Introduction
All Manuals
Mill - APL - Operator's Manual Supplement
  • 0 - Mill APL - Table of Contents
  • 1 - Mill APL - Introduction
  • 2 - Mill APL - Legal Information
  • 3 - Mill APL - Safety
  • 4 - Mill APL - Installation
  • 5 - Mill APL - Control Icons
  • 6 - Mill APL - Operation
  • 7 - Mill APL - Programming
  • 8 - Mill APL - M-codes
  • 9 - Mill APL - Settings
  • 10 - Mill APL - Maintenance
  • 11 - Mill APL - Workholding
  • 1.1 Introduction
  • 1.2 Axis Definitions
  • 1.3 Specifications
  • 1.4 How To Use This Manual
1.1 Introduction
This operator’s manual supplement describes the unique features and functions of the Mill Automatic Parts Loader. Refer to your Mill Operator’s Manual for control operation, programming, and other general mill information.
Specific details about the Mill Automatic Parts Loader itself, including information that is beyond the scope of this document, can be found at www.HaasCNC.com.
The Haas Automatic Parts Loader is a simple and affordable way to automate part production and boost productivity. It is designed and built exclusively for use on Haas small VMCs, and connects directly to the Haas control.
Mill APL - Axis Definitions
  1. AW-Axis [1] this axis moves the ram up and down.
  2. AU-Axis [2] this axis moves across the ram left to right.
  3. AV-Axis [3] this axis moves the table front to back.
  4. Grippers
  5. Light Curtain Sensor
NOTE: The APL is equipped with a light curtain sensor, which will stop the APL motion any time it senses the operator moved into the light curtain zone. If a program is running it will not be interrupted by the light curtain. Cycle Start will continue APL motion.
1.3 Specifications
Mill APL - Specifications
For Mill APL - Specifications, see the machine layout drawing for more info.
Mill APL - Layout Drawing
How to Use This Manual
To get the maximum benefit of your new Haas machine, read this manual thoroughly and refer to it often.
IMPORTANT:  Before you operate the machine, read and understand the Operator’s Manual Safety chapter.
DECLARATION OF WARNINGS
Throughout this manual, important statements are set off from the main text with an icon and an associated signal word: “Danger,” “Warning,” “Caution,” or “Note.” The icon and signal word indicate the severity of the condition or situation. Be sure to read these statements and take special care to follow the instructions.
Description Example
Danger means that there is a condition or situation that will cause death or severe injury if you do not follow the instructions given.  DANGER: No step. Risk of electrocution, bodily injury, or machine damage. Do not climb or stand on this area.
Warning means that there is a condition or situation that will cause moderate injury if you do not follow the instructions given.  WARNING:  Never put your hands between the tool changer and the spindle head.
Caution means that minor injury or machine damage could occur if you do not follow the instructions given. You may also have to start a procedure over if you do not follow the instructions in a caution statement. CAUTION: Power down the machine before you do maintenance tasks.
Note means that the text gives additional information, clarification, or helpful hints. NOTE:  Follow these guidelines if the machine is equipped with the optional extended Z-clearance table.
Description Text Example
Code Block text gives program examples. G00 G90 G54 X0. Y0.;
A Control Button Reference gives the name of a control key or button that you are to press.  Press [CYCLE START].
A File Path describes a sequence of file system directories.  Service > Documents and Software >...
A Mode Reference describes a machine mode.  MDI
A Screen Element describes an object on the machine’s display that you interact with.  Select the SYSTEM tab.
System Output describes text that the machine control displays in response to your actions.  PROGRAM END
User Input describes text that you should enter into the machine control.  G04 P1.;
Variable n indicates a range of non-negative integers from 0 to 9. Dnn represents D00 through D99.
