4 - Mill APL - Installation
Mill - APL - Operator's Manual Supplement
  • 0 - Mill APL - Table of Contents
  • 1 - Mill APL - Introduction
  • 2 - Mill APL - Legal Information
  • 3 - Mill APL - Safety
  • 4 - Mill APL - Installation
  • 5 - Mill APL - Control Icons
  • 6 - Mill APL - Operation
  • 7 - Mill APL - Programming
  • 8 - Mill APL - M-codes
  • 9 - Mill APL - Settings
  • 10 - Mill APL - Maintenance
  • 11 - Mill APL - Workholding
  • 4.1 Mill APL - Installation
  • 4.2 APL Bar Stock Template - Installation
The Mill and Lathe installation procedures are located on the Haas Automatic Parts Loader - Interactive Service Manual.  Click on the image below.
AD0478
Install Bar Template
Install the Bar Template Locator[1] with the following hardware:
  • 8 x SHCS 1/4-20
Note: These templates can also be used on Mill APL's, but the templates are the same as the lathe's. Refer to the Lathe APL operator's manual for specifications.
Install the Bar Template Stops[1] and Bar Template Holders[2]. The template is installed depending on the stock size used. This can be found in the Lathe APL Operator's Manual.
Note: Install the templates so the bar stock is equal distance from each other when located against a stop.
Install with the following hardware:
  • 80 x FBHCS 1/4-20
Install Bar Grippers
If the gripper fittings[1] are on the inside of the assembly, rotate the gripper bodies 180 degress so they are facing outside. This will allow for more clearance when loading bar stock.
If the slug style grippers are installed, remove the gripper plates from the gripper bodies.
Install the Bar Gripper Bolt Plates[1] using the following hardware: 8 x SHCS M6[2]
Install the Bar Gripper Fingers[3] using the following hardware: 8 x SHCS 1/4-20[4]
The location of the bar fingers is dependent on the stock size. The Lathe APL Operator's Manual has recommended locations for specific stock size.
