7 - Mill APL - Programming
Mill - APL - Operator's Manual Supplement
  • 0 - Mill APL - Table of Contents
  • 1 - Mill APL - Introduction
  • 2 - Mill APL - Legal Information
  • 3 - Mill APL - Safety
  • 4 - Mill APL - Installation
  • 5 - Mill APL - Control Icons
  • 6 - Mill APL - Operation
  • 7 - Mill APL - Programming
  • 8 - Mill APL - M-codes
  • 9 - Mill APL - Settings
  • 10 - Mill APL - Maintenance
  • 11 - Mill APL - Workholding
  • 7.1 Mill APL - Programming
APL Stop / Resume Feature
This feature lets you stop (interrupt) a running part program during an Automatic Part Loading cycle (APL Mode) and resume normal operation from any part in the program. The APL will not lose part count, and it will continue the part load and unload cycle.
Note: In order to pause an APL job, the following must be done.
  1. The part program must be stopped with any program stop command (M00, M01, M02, M30).
  2. The APL must reach the “At Ready” position before hitting reset.
 Note: If any of the following are done while an APL job is paused, the job will be canceled, and a new one will need to be started.
  1. Cycle power the machine.
  2. Change or edit APL jobs.
  3. Taking the control out of “APL Mode”.
  4. Interrupt the APL while the door is open and the arm is inside the machine
  5. Manipulate any APL mechanisms, such as the grippers/rotator.
  6. Jog any APL axis or select an APL axis for jogging.  Warning: If the last jogged axis was an APL axis pressing the handle job will cancel the APL job.
After resetting the control an operator may switch to MDI mode, EDIT mode,  JOG Mode to do any changes or part inspections as needed. All operation is normal at this point.
When the operator is ready to resume Part Machining in APL Mode. Press [MEMORY] and then put the cursor on the Tool Callout (e.g. T0505) where you want the program to start from. Do not start in the middle of the program since this may cause unintended motion.
With the control still in APL Mode press [CYCLE START] and resume part machining and APL operation.
