Axis-Lubrication System - Grease Reservoir - Prime and Test
If the machine has a Classic Haas Control:
  • Press [PARAMETER DIAGNOSTIC] (2) times to show the diagnostics page.
  • Press [CANCEL].
  • Go to the LUBE tab.
  • Press [WRITE/ENTER].
  • Press [F2] to start the Axis-Lubrication Test.
If the machine has a Next Generation Control:
  • Press [DIAGNOSTICS].
  • Go to the Maintenance tab.
Perform the Axis-Lubrication Test again until you no longer get axis lubrication alarms. Wait a minimum of (1) minute between Axis-Lubrication Test cycles.
Check the level of the grease in the reservoir.
If the grease lines were nearly empty, it may be necessary to refill the axis-lubrication reservoir after you purge the lines of air. Pour the grease into the reservoir: to about 1/2" (13 mm) below the threads on the reservoir.
