UMC - Pendant Installation
Attach the storage cabinet to the side of the machine.
Put the pendant spacer [1] onto the storage cabinet. Place the pendant onto the spacer.
Attach the washer [2] and shoulder screw [3] to the bottom of the pendant.
Attach the pendant [4] to the top of the storage cabinet.
Pull the pendant cables sticking outside the machine's enclosure. Push the pendant cables into the pendant [4]. Install the cover [5] over the wires.
 NOTE: Make sure not to pinch any wires when installing the cover.
Remove the rear panel of the pendant. Connect these cables:
  • Remote Jog handle cable [1] to P9
  • Power cable [2] to J20
  • USB cable [3] to J9
  • Ethernet cable [4] to J28
Install a ferrite [5] onto the USB cable [3] connected to SKBIF J9 connection.
Install a ferrite [5] on the touchscreen cable [6] connected to SKBIF J11 connection.
 NOTE: Make sure to loop the USB cable within the ferrite [5] as shown.
Attach the ground wire [7] from pendant to the control cabinet. Use any available grounding screw on the inside of the control cabinet.
