5-Axis - Machine Accuracy​ Test Procedure - AD0817
Service Home How To Procedures 5-Axis - Machine Accuracy​ Test Procedure - AD0817
Recently Updated Last updated: 10/13/2025
AD0817
- Jump to Section - 1. Overview 2. HFO Steps 3. Thermal Growth Test Procedure 4. Machine Geometry & MRZP Test Cut​ Back to Top
Overview
 Download and fill out the 5-Axis Machine Accuracy Test Procedure Checklist below.
Use the following test procedure to determine the root cause of the Machine Accuracy problem.
HFO Steps​:
  • Customer complaint of part geometry not matching print. What feature(s)?​
  • HFO Applications reviews machine history, machine level, program, and part setup.​
  • Verify Probe is calibrated.​
  • Redo MRZP.
  • Rerun customer program.​
Thermal Growth Test Procedure​:
  • If the measured part error consistent throughout the day, continue to Machine Geometry steps.​
  • If the part error changes throughout the day, continue thermal growth test procedure.​
Machine Geometry & MRZP Test Cut​:
  • Complete Inspection Report and submit Error Report.​
  • Passes Inspection Report > Test Cut​
  • Fails Inspection Report > Correct Geometry​ > Test Cut
HFO Steps
    • What feature(s).
    • Tolerance and measured value.
    • Customer Expectations​.
    • Is the measured part error consistent throughout the day or does the part error change throughout the day.
    • If it changes throughout the day, continue to Thermal Growth test steps.​
    • Did machine geometry change because of crash, machine level, software/configurations?​
    • Applications Part Geometry Checklist from ID0039.​
      • Workholding, tooling, coolant, machining.
  • Redo MRZP.
  • Run customer program. Did it improve and meet print? Continue Machine Geometry test steps.
  • If the part error is consistent throughout the day, continue to Machine Geometry section.​
  • If the part error changes throughout the day, continue Thermal Growth test procedure.​
  • Complete Thermal Growth Checklist from ID0034.
    • Verify machine hardware is not contributing to thermal growth.​
      • Ballscrew and Axis Lubrication system functioning correctly.​
      • Spindle Fan and Spindle Lubrication system functioning correctly.​
      • Spindle Chiller operating correctly.​
    • Verify Shop Environment.​
      • What is the shop temperature throughout the day? What is the max and minimum temperature?​
      • Does a HVAC vent discharge near the machine?​
      • Is the machine near a doorway?​
    • Adequate spindle and axis warmup time before machining parts.​
      • Run customer program for minimum 20 minutes with Z-Axis offset to avoid part.​
    • Run Thermal Growth Test Program.​
      • Attach DPRNT and Error Report to the work order and contact the Haas Service Department for review.​
  • Fails Inspection Report > Correct Geometry​ > MRZP Test Cut
  • Change MRZP settings based on measured test cut features.​
  • Redo test cut. Did part geometry improve?​
  • Run customer part. Did part geometry improve?
UMC - MRZP Test Cut
VR/GM-2-5AX - MRZP Test Cut
HDC-3-5AX - MRZP Test Cut
