      • Surface Roughness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
UMC - MRZP Test Cut Kit - AD0545
Service Home How To Procedures UMC - MRZP Test Cut Kit - AD0545
Recently Updated Last updated: 05/27/2025
AD0545
Revision A - 5/2025
- Jump to Section - 1. UMC - MRZP Test Cut - Setup 2. UMC - MRZP Test Cut - Equipment List 3. UMC - MRZP Test Cut - Tool List 4. UMC - MRZP Test Cut - MRZP Settings Adjustment (7 steps) Back to Top
This procedure applies to the following service kits:
  • 93-3347  - CT40 MRZP TEST CUT KIT
  • 93-3793  - BT40 MRZP TEST CUT KIT
  • 93-3792 - HSK63A MRZP TEST CUT KIT
Demo Description:
This part is done in one operation and is designed to check the MRZP settings on a UMC machine.
The Tool Length and Work Offsets must be set with the Probing System.
Inch Part Program:
O00011.nc
Metric Part Program:
O00011MM.nc
Set G54 Offset:
Bolt the vise to the center of the table as show in photo. Part center must be within 2 inches of the center of the table.
G54 X zero is center of the stock.
G54 Y zero is center of the stock.
G54 Z zero is 0.02 inches below the top of stock.
G54 B zero is B0. Machine position
G54 C zero is C0. Machine position
Machine Warm Up:
Note: The machine must be warmed up before cutting the test cut part.
Important: Run the test cut program with a Z-Axis offset to avoid part.​
Note: Probe the tool length offsets after running the warm up program.
Part Number Quantity Description
99-05-0090 1 Haas Riser For 5" Self Centering Vise
99-05-0004 1 5" Manual Self Centering Vise
99-03-0573 2 ½” End Mill 3 Flute With .030" Radius
99-01-0159 1 45 Degree Small Chamfer Mill
99-02-0505 1 Small Chamfer Mill Insert
99-04-0004 1 CAT40 ¾” End Mill Holder
99-04-0011 1 CAT40 ER32 Collet Chuck 4” Gage Length
99-04-0006 1 CAT40 ER16 Collet Chuck 2.5” Gage Length
99-04-0200 1 CAT40 Solid Pull Stud (10 pack)
99-04-0250 1 ER-32 Collet 13
99-04-0218 1 ER-16 Collet 4
99-03-2088 2 1/8” Ball End Mill
N/A 1 6061 Aluminum 4 Inch x 4 Inch Bar Cut To 2.5 Inch
99-04-0145 1 BT40 ER16-70
99-04-0150 1 BT40 ER32-100
99-04-0160 1 BT40 EM 0.75 - 63
99-04-0250 1 ER32-13 MM Collet
99-04-0296 3 BT40 Pull Stud Solid 1 Each
99-04-0261 1 HSK63A ER32-100
99-04-0262 1 HSK63A ER16-160
99-04-0819 1 HSK63A EM 0.75 - 3.15
Tool Number 1:
Cutter Type: ½” End Mill 3 Flute with .030" Radius
Holder Type: ER Collet
RPM: 10,000
Number of  Flutes: 3
Minimum Working Length: 1.9"
Tool Number 2:
Cutter Type: ” ¾” Chamfer Tool
Holder Type: Weldon
RPM: 10,000
Number of  Flutes: 1
Minimum Working Length: 2.75"
Tool Number 3:
Cutter Type: 1/8” Engraving Tool
RPM: 10,000
Number of  Flutes: 2
Minimum Working Length: 1.0"
With the part in the vise, use a indicator to measure the step between the two tool paths.
Measure the step on either side of the pocket.
Measure these two locations on all four sides of the part and use the Y+ and X+ arrows to record the measurements below.
If there is a step out from the top surface to the bottom surface, record a positive value. If there is a step in from the top surface to the bottom surface, record a negative value.
Note: This step should be less than 0.001”.
  Left Side Right Side
X+
X-
Y+
Y-
Adjust setting 255 MRZP X OFFSET or settings 300 MRZP X OFFSET MASTER and setting 303 MRZP X AXIS SLAVE until the X+ and X- results match.
  • If the X+ side has a positive step and the X- side has a negative step, adjust these settings in the positive direction by half the difference.
  • If the X+ side has a negative step and the X- side has a positive step, adjust these settings in the negative direction by half the difference.
Adjust setting 256 MRZP Y OFFSET or setting 304 MRZP Y AXIS SLAVE until the Y+ and Y- results match.
  • If the Y+ side has a positive step and the Y- side has a negative step, adjust these settings in the positive direction by half the difference.
  • If the Y+ side has a negative step and the Y- side has a positive step, adjust these settings in the negative direction by half the difference.
Once all four sides have the same step, adjust setting 257 MRZP Z OFFSET or setting 302 MRZP Z AXIS MASTER.
  • If all four sides have a negative step, adjust these settings in the negative direction.
  • If all four sides have a positive step, adjust these settings in the positive direction.
The tool length offset can also be used to adjust the step on all four sides of the part. If a large adjustment is needed, you need to make sure the probe calibration was done correctly.
With a micrometer, measure the distance between the top face and pocket. Measure in two locations, the left and right side of the pocket. Record the measured values for all four sides of the part.
This distance should be 0.625” +/- .001”
X+
X-
Y+
Y-
If this distance is not 0.625” +/- .001” there could be a problem with the machine geometry.
  1. Check to make sure the B axis is going to B90 by running an indicator along the Z axis on the face of the table at B90. This should measure less than +/- .003” over 10.0”
  2. Check to make sure the platter is flat at B0 by running an indicator along the X axis on the face of the table at B0. See the UMC inspection report. This should measure less than +/- .001” over 20”
  3. If the distance is different between the left and right measurement, check the geometry by running an indicator along the Y axis on the face of the platter at B90 and B-90. See the UMC inspection report. This should measure less than +/- .001” over 20.0”
  4. If the 0.625” distance is different on the four sides of the part, the table could be running out as the C axis rotates, check the face of the platter at C0, C90, C180, C270. See the UMC inspection report. Platter face runout not to exceed .0005”.
With a micrometer, measure the distance between the side face and pocket. Measure in two locations, the left and right side of the pocket. Record the measured values for all four sides of the part.
X+
X-
Y+
Y-
These values should be correct if the values in Step 3 are set correctly.
If you are seeing a difference between the left and right side measurements, make sure the X axis is perpendicular to the B axis centerline. This can be done by zeroing an indicator on the front of the part at B0 & C0. Then rotating the B axis to B90 and touching the indicator on the front of the part to see if the front of the part is moving along the Y axis as the B axis tilts. The measured difference between these two points should not exceed .002”.
If you have any problems adjusting the values in these three steps, you will need to fill out a full inspection report and adjust the machine geometry as needed.
