VR/GM-2-5AX - MRZP Test Cut Kit - AD0772
Service Home How To Procedures VR/GM-2-5AX - MRZP Test Cut Kit - AD0772
- Jump to Section - 1. VR/GM-2-5AX - MRZP Test Cut - Setup 2. VR/GM-2-5AX - MRZP Test Cut - Equipment List 3. VR/GM-2-5AX - MRZP Test Cut - Tool List 4. VR/GM-2-5AX - MRZP Test Cut - X/Y Squareness (1 step) 5. VR/GM-2-5AX - MRZP Test Cut - MRZP Settings 300 & 301 Adjustment (3 steps) 6. VR/GM-2-5AX - MRZP Test Cut - MRZP Setting 303 Adjustment (1 step) 7. VR/GM-2-5AX - MRZP Test Cut - MRZP Setting 305 Adjustment (1 step) 8. VR/GM-2-5AX - MRZP Test Cut - B/C Geometry (1 step) Back to Top
Recently Updated Last updated: 05/27/2025
AD0772
Revision A - 5/2025
This procedure applies to the following service kits:
  • 93-3792 - HSK63A MRZP INCH TEST CUT KIT
Demo Description:
This part is done in one operation and is designed to check the MRZP settings on a VR or GM-2-5AX machine.
The Tool Length and Work Offsets must be set with the Probing System.
Inch Part Program:
O00023.nc
Metric Part Program:
O00024.nc
Set G54 Offset:
Bolt the vise to the center of the table as show in photo.
G54 X zero is center of the stock.
G54 Y zero is center of the stock.
G54 Z zero is 0.02 inches below the top of stock.
G54 B zero is B0. Machine position
G54 C zero is C0. Machine position
Machine Warm Up:
 Note: The machine must be warmed up before cutting the test cut part.
 Important: Run the test cut program with a Z-Axis offset to avoid part.​
 Note: Probe the tool length offsets after running the warm up program.
Part Number Quantity Description
99-01-0159 1 45 Degree Small Chamfer Mill
99-02-0505 1 Small Chamfer Mill Insert
99-03-0573 2 ½” End Mill 3 Flute With .030" Radius
99-03-2088 2 1/8” Ball End Mill
99-04-0218 1 ER-16 Collet 4
99-04-0250 1 ER-32 Collet 13
99-04-0261 1 HSK63A ER32-100
99-04-0262 1 HSK63A ER16-160
99-04-0819 1 HSK63A EM 0.75 - 3.15
99-05-0004 1 5" Manual Self Centering Vise
99-05-0090 1 Haas Riser For 5" Self Centering Vise
N/A 1
Inch Part Program - 6061 Aluminum 4 Inch x 4 Inch Bar Cut To 2.5 Inch
Metric Part Program - 6061 Aluminum 100mm x 100mm Bar Cut To 65mm
Tool Number 1:
Cutter Type: 0.5” End Mill 3 Flute with .030" Radius
Holder Type: ER Collet
RPM: 10,000
Number of Flutes: 3
Minimum Working Length: 1.9"
Tool Number 2:
Cutter Type: 0.75” Chamfer Tool
Holder Type: Weldon
RPM: 10,000
Number of Flutes: 1
Minimum Working Length: 2.75"
Tool Number 3:
Cutter Type: 0.125” Engraving Tool
RPM: 10,000
Number of Flutes: 2
Minimum Working Length: 1.0"
Measure the outside square cut with the side of the End Mill. This should measure 3.95” +/- .001" along the X and Y axis.
If this does not measure correctly, check to make sure you are using the correct size End Mill and do a ball bar test to make sure the X to Y axis ratio is correct.
With the part in the vise, use an indicator to measure the step between the two tool paths.
Measure the step on either side of the pocket.
Measure these two locations on all four sides of the part and use the Y+ and X+ arrows to record the measurements below.
If there is a step out from the top surface to the bottom surface, record a positive value. If there is a step in from the top surface to the bottom surface, record a negative value.
Note: This step should be less than 0.001”.
  Left Side Distance Right Side Distance
X+
X-
Y+
Y-
Adjust setting 300 MRZP X OFFSET MASTER until the X+ and X- results match.
  • If the X+ side has a positive step and the X- side has a negative step, adjust these settings in the positive direction by half the difference.
  • If the X+ side has a negative step and the X- side has a positive step, adjust these settings in the negative direction by half the difference.
Adjust setting 301 MRZP Y OFFSET MASTER until the Y+ and Y- results match.
  • If the Y+ side has a positive step and the Y- side has a negative step, adjust these settings in the positive direction by half the difference.
  • If the Y+ side has a negative step and the Y- side has a positive step, adjust these settings in the negative direction by half the difference.
Adjust these settings until all four sides on the part have the same step. The step does not need to be +/- .001" at this point they just need to be the same on all four sides. The next two adjustments will change this step value.
With a micrometer, measure the distance between the top face and pocket. Record the measured values for the two sides of the part.
This distance should be 0.500” +/- .002”
Adjust Setting 303 MRZP X AXIS SLAVE.
  • If X+ side is larger than the X- side, adjust these settings by the half the difference of the two measurements in the negative direction.
  • If X- side is larger than the X+ side, adjust these settings by the half the difference of the two measurementsin the positive direction.
Adjust this setting until the X+ and X- sides measure the same. They do not need to be 0.500". They just need to be the same. The next adjustment will change the measurement of both sides.
Note: Adjusting setting 303 will also change the depth of these two cutouts.
  Distance
X+
X-
With a micrometer, measure the distance between the top face and pocket. Measure in two locations, the left and right side of the pocket. Record the measured values for all four sides of the part.
This distance should be 0.625” +/- .002”
If all four sides have the same error, adjust setting 305 MRZP Z AXIS SLAVE until all four sides are 0.625" +/- .002"
  • If all four sides are too large, adjust the settings of the measured error in the negative direction.
  • If all four sides are too small, adjust the settings of the measured error in the positive direction.
This adjustment will also change the measurement in step # 2 and step # 3
X+
X-
Y+
Y-
With a micrometer, measure the distance between the side face and pocket. Measure in two locations, the left and right side of the pocket. Record the measured values for all four sides of the part.
This distance should be 0.625” +/- .004”
These values should be correct if the values in MRZP Settings 300 & 301 Adjustment are set correctly.
At this point all the measurements in steps 1 through 4 should have the correct values. If they do not, go through steps 1 through 4 again. If this does not fix the measurements, you will need to fill out a full inspection report and adjust the machine geometry as needed.
X+
X-
Y+
Y-
