Air Purge Solenoid - Maintenance
Service Home How To Procedures Air Purge Solenoid - Maintenance
Recently Updated Last updated: 03/18/2021
Applies to machines built from: January, 2014
- Jump to Section - 1. Rebuild 2. ASCO Brand Purge Solenoid 3. SMC Brand Purge Solenoids Back to Top
Rebuild
If your purge valve is leaking or not functioning correctly, it is most likely because debris got inside the air purge solenoid. This procedure tells you how to clean both ASCO and SMC brand air purge solenoids.
 Do not replace a purge solenoid unless you have tried to clean and rebuild.
Push [POWER OFF].
Close the primary air valve. This stops the air supply to the machine.
Push [POWER OFF].
Close off the water supply valve to the refill unit.
ASCO air purge solenoid:
  • Remove the red cap [1].
  • Push the solenoid coil assembly [2] down to compress the spring inside.
  • Remove the specification plate [3] by sliding off.
  • Remove the split spring [4] and valve subassembly [5] from the coil assembly [2].
  • Disassemble the valve subassembly [5].
  • Clean the parts with compressed air. Be sure to remove all debris from inside the valve.
  • Apply a thin coat of silicone grease to the body gasket [6].
  • Assemble the components in the opposite order they were removed.
  • Open the primary air valve. Make sure there are no leaks.
Push [POWER OFF].
SMC air purge solenoid:
  • Remove the four screws [1].
  • Remove the solenoid coil assembly [2].
  • Clean the internal solenoid parts [3] with compressed air. Be sure to remove all debris from inside the valve [4].
  • Apply a thin coat of silicone grease to the rubber seals.
