Sigma-1 - Axis Servo Motor Cable - Molded - Replacement
Service Home How To Procedures Sigma-1 - Axis Servo Motor Cable - Molded - Replacement
Recently Updated Last updated: 12/22/2023
- Jump to Section - 1. Introduction 2. Replacement (1 step) Back to Top
This procedure tells you how to replace these brushless axis cables:
  • 2-Cable set: motor power and encoder
  • 3-Cable set: motor power, encoder, and brake
Replacement
Put labels on the locations of the cables you will replace.
  • The encoder cable connection location is on the processor PCB [1]
  • The power cable connection location is on the amplifier [2]
  • If you have a brake cable, the connection is on the I/O PCB [3]
Disconnect the cables from the control cabinet and the motor. Remove the cable from the machine.
Fill the amphenol connectors on the motors [4] with dielectric grease.
IMPORTANT: Make sure to only place grease on on the contact points of the connectors. Do not apply excess grease to the entire face of the connector. This can cause damage to the servo motor.
Install the new cables.
Install the cable housing [5] to the control cabinet wall. Use the (4) screws [6].
