Haas Compact APL Fence - Installation - AD0645
Service Home How To Procedures Haas Compact APL Fence - Installation - AD0645
6.2 Compact APL - Fence Installation
Recently Updated Last updated: 09/29/2023
AD0645
This procedure outlines how to assemble the fence for the Compact APL.
The fence consists of 3 sides, the door and frame [1], the side panel of the frame [2], and the back panel of the frame [3].
The fence comes partially assembled in the 4 pieces shown at the bottom of the image.
Attach the door [1] to the frame [2] as shown using the hinges [3] with the screws [7] and t-nuts [6] provided.
Note: The hinges should be attached on the right side of the door and frame as shown in the image.
Attach the foot bracket [1] to the fence's door as shown.
Attach the side panel of the fence to the door and frame assembly using the (2) joining plates as shown in [2] and the foot plate as shown in [1].
Attach the back panel of the fence to the side panel of the fence using the (2) joining plates as shown in [2] and the foot plate as shown in [1].
Attach the foot bracket [1] to the fence's back panel.
Attach the fence sheet metal panels [1]&[2] to the machine as shown.
The Compact APL Fence should be set up against the machine as shown. Attach the fence to the sheet metal panels that were attached to the machines in the previous step.
Interlock and Remote E-Stop
Fortress Interlock 2
Follow the insctructions below for the fortress interlock 2.
With the key inserted in the interlock, the two red LED lights in the front of the interlock should be off [1].
On the Haas pendant, there should not be any E-stop or light curtain/fence alarms or icon triggered.
Remove the key from the interlock. The two red LED lights should turn on [2] and a warning should appear on the Haas pendant for light curtain/fence.
Press the Pendant and RJH-XL E-STOP buttons and make sure the machine generates 107 EMERGENCY STOP alarm. If the E-STOP button does not generate a 107 EMERGENCY STOP alarm verify the wiring. Load the latest configuration files to enable the RJH-XL.
 Warning: By not putting the jumpers in the vertical position, E-STOP functionality on the RJH-XL is disabled and the machine is considered unsafe. Jumpers MUST be inserted vertically.
