DS/ST-30 Sub-Spindle Conduit Retention - AD0822
Service Home How To Procedures DS/ST-30 Sub-Spindle Conduit Retention - AD0822
- Jump to Section - 1. Introduction 2. Installation (5 steps) Back to Top
Recently Updated Last updated: 04/28/2025
DS/ST-30 - Sub-Spindle Conduit Retention - Installation
AD0822
Revision A - 04/2025
This procedure shows how to install a sub-spindle conduit retainer in all ST/DS-30/Y machines.
This Document Applies to the following Service Kits:
  • 93-4965 DS/ST-30 SUB-SPNDL CONDUIT RETENTION
Machine Compatibility :
  •     ST/DS-30/Y built after 04/03/2019
Assemble the upper components of the retainer. Slide the spring [1] into the clamp [2] then use the provided counter sunk bolt [4] on the back side of the magnetic puck [3] and attach the nut [5].
Slip the hose clamp [1]  onto the sub-spindle conduit then secure to the spring using the bolt [2] and nut [3] on the back face.
Relocate the hose clamp in the machine to one of the two illustrated position [1] or [2] to prevent kinks in the line.
Jog the sub-spindle towards the main spindle and verify that that the conduit retainer is preventing the drain conduit from sagging downwards.
Jog the sub-spindle to the home position and verify that the conduit is not being tangled or kinked.
