E-Vise LVPS - Replacement - AD0589
Service Home How To Procedures E-Vise LVPS - Replacement - AD0589
4.3 E-Vise LVPS - Replacement
Recently Updated Last updated: 04/18/2022
AD0589
This product has been discontinued, documentation is for reference only.
This procedure oulines how to replace the E-Vise LVPS and PCB assembly.
Note: This procedure is only the the E-Vise LVPS and PCB replacement, refer to the E-Vise Field Install and E-Vise Ready Install procedures for the field install instructions.
This procedure applies to the following service kit:
  • 93-3270: CAN E-VISE ELECTRICAL ASSEMBLY KIT 2020
Removal
Remove the old e-vise power supply and PCB assembly from the I/O hinge door.
Replacement
Install the power supply and PCB assembly [4] to the I/O hinge door.
Connect the cables to the new e-vise power supply and PCB assembly as they were to the old assembly:
33-5308 [1] E-Vise CAN PCB to I/O PCB
33-0644 [2] E-Vise CAN PSUP to PSUP PCB
33-5400 [3] E-Vise CAN PCB to Smart CAN Auto Door PCB
Verify that all cables for the CAN device(s) are correct.
Connect cable 33-0645 [1] from J6 on the E-Vise CAN PCB to the E-Vise connector.
Connect cable 32-1390 [2] from P14 on the I/O PCB to the foot pedal.
Connect cable 33-5308 [3] from J1 on the E-Vise CAN PCB to J2 on the I/O PCB.
 Note: If the machine is equipped with CAN Auto Door. Unplug cable 33-5310 [7] from J2 on the I/O PCB. Connect cable 33-5400 [4] from J3 on the E-Vise CAN PCB to cable 33-5310 [7] plugged into J1 on the Auto Door CAN PCB. If it does not have CAN Auto Door, coil the cable and zip tie it to the I/O Hinge Door.
 Note: Cable 33-0647 is wired from the factory. For reference only.
Connect cable 33-0644 [6] from the E-Vise PSUP to P5 on the PSUP PCB.
 Note: If there is a cable plugged into P5, unplug it and plug it into the pigtail connection on cable 33-0644.
