Eco Mode - Eco Mode Plus Field Install - AD0896
Service Home How To Procedures Eco Mode - Eco Mode Plus Field Install - AD0896
21.4 Mill - Eco Mode - Eco Mode Plus Field Install
Recently Updated Last updated: 09/10/2025
AD0896
Revision A - 09/2025
Eco Mode Plus uses hardware to monitor and log the Voltage and current the machine is using. It can use these logs to estimate the electrical cost of operating the machine.
This procedure only applies to machines with 19-inch controls.
Minimum software version: 100.25.001.1200.
Minium IO board firmware: 4.31
This document applies to: 93-1001256 ECO MODE DS9 HARDWARE FIELD INSTALL
Note: Eco mode plus is only available for machines that only use three-phase power. Machines that can be configured for either one or three phase cannot use Eco Mode Plus.
Note: Machines built before October 2025 are built with 33-9943. This kit requires 33-9943A and must be ordered separately if the machine was built without that cable. See the installation section for identification information between these two cables.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting/disconnecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. The electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key, and open the door.
Determine if the machine has 33-9943 or 33-9943A installed. This cable goes from the top of the K1 contactor to P14 on the PSUP.
33-9943A will have an additional loose plug [1] while 33-9943 will only have connections from the K1 to the PSUP.
If the machine already has 33-9943A, skip to step 6.
The K1 contactor is commonly placed behind the breaker, so if cable 33-9943 needs to be replaced, it may be necessary to remove the breaker.
It is important that the pins on 33-9943A are placed into the correct terminals on the K1 contactor. They should be placed left to right: 71-L1 [1], 72-L2 [2], and 73-L3 [3]. These will match the labels on cable 33-9943 that is being removed.
Plug the male connector on 33-9943A into P14 [4] on the top right of the PSUP.
Remove the L74 [1] and L76 [2] taps from the transformer and run them through the current meters on the Eco Mode assembly.
Use the magnets on the back of the Eco Mode board assembly to attach the assembly to the side of the cabinet.
Reconnect the L74 and L76 to the transformer taps.
Plug cable 33-1557 into the Eco Mode board [1] and into the pigtail on cable 33-9943A [1].
Connect J2 [2] either to the previous CAN node or the IO board.
Connect J3 [3] to the next CAN node.
See the CAN Manual for diagrams and Node orders. CAN Bus Systems - Service Manual
Reconnect the power and turn the machine on.
Pull the latest configuration files from HBC and apply them to the machine. Configuration File - Download/Load - NGC
Since this procedure makes changes to the CAN BUS system, it is likely that several CAN BUS and IO alarms will be generated once the machine is powered on. Review the alarms that are generated and resolve them. See the CAN Bus Troubleshooting guide for additional details.
