9 - CAN Bus Systems - Troubleshooting
CAN Bus Systems - Service Manual
  • 1 - CAN Bus Systems - Introduction
  • 2 - CAN Bus Systems - Diagnostics
  • 3 - CAN Systems - Autodoor
  • 4 - CAN Bus Systems - E-Vise
  • 5 - CAN Bus Systems - CAN Lube Panel and Spindle Head
  • 6 - CAN Bus Systems - Compact APL
  • 7 - CAN Bus Systems - Active Ballscrew Compensation
  • 8 - Can Systems - Motion Sensor
  • 9 - CAN Bus Systems - Troubleshooting
  • 9.1 CAN Bus Systems
  • 9.2 CAN Lube Panel and Spindle Head
  • 9.3 Compact APL
  • 9.4 Autodoor
  • 9.5 Active Ballscrew Compensation
9.1 CAN Bus Systems Troubleshooting Guide
CAN Bus Systems - Troubleshooting Guide
TG0043
Revision C - 05/2026
Controller Area Network (CAN) is a robust vehicle bus standard designed to allow microcontrollers and devices to communicate with each other. This method is used to create satellite nodes grouped by function that can be expanded on without changing the core electronics.
Each board has a node ID selection switch [SW2] that must be set correctly.
Devices are connected in Daisy Chain.
Each board has a termination switch [SW1] that must be set correctly.
Note: The last device on the chain needs to be terminated.
The overall CAN System sequence should be connected in the order that follows: Active Ballscrew Compensation > CAN E-Vise > Compact APL > Motion Sensor > CAN Autodoor.
Important: The CAN system at the end of the sequence will vary by machine and depends on what options the machine has. The last CAN system in the sequence should have their termination switch on the TERM setting. The only exception of this is if the Motion Sensor is the last CAN System in the sequence, this board does not have a termination switch and will need a jumper (PN: 32-1306) installed at J3 if it is the last CAN System.
Board Locations
1.  VMC CAN Spindle Head PCB
2. CAN Lube Panel PCB
Updated
3.  UMC CAN Spindle Head PCB
Note: For UMC-400 machines, the spindle head CAN box IO is located at the back of the ram, not at the top of the spindle head.
4. Lathe CAN Spindle Head PCB
5. CAN Autodoor
6. CAN E-Vise
Node ID Selection
Device Node ID Factory Setting
IO Board 3 N/A
CAN Autodoor 13 (D on selector) 9013.001
CAN Electric Vise 11 (B on selector) 9011.001
CAN Lube Panel 5 9005.001
CAN Spindle Head 7 9007.001
Legacy CAN Autodoor 9 9009.001
Compact APL 15 (F on the selector) 9015.001
Active Ballscrew Compensation 20 (4 on the selector) 9020.001
Updated
 IMPORTANT: If the I/O board loses communication with a CAN system, it will stop communicating with all other devices on the CAN network.
IMPORTANT: Resolve the CAN communication fault completely before proceeding with further troubleshooting.
ALARM / CAN CODE
BEFORE SOFTWARE 100.21.000.1100:
Alarm 9898.001: CAN NODE WARNING
CAN code [0x43]: CAN NODE WARNING
SOFTWARE 100.21.000.1100 and Later:
Alarm 9706 or (100.001): CAN NODE COMMANDED CURRENT OUT OF RANGE
CAN code [0x43]
Outdated Firmware & Parameters Upgrade to the latest Software, Configuration files, and I/O / CAN AD Firmware.
Alarm 9701: Node ID: XX Node reported it lost communication from I/O board
CAN code [0x01]
Old IO firmware. Load I/O firmware 4.09 or greater.
Poor connection Verify CAN Bus Connectors are fully seated and termination resistor set correctly.
Alarm 9899 IOPCB CAN FAULT and/ or Alarm 9105 IO BOARD COMMAND EXECUTION FAILURE The CAN node I/O Configuration is incorrect. Update the I/O configuration via the I/O Config tab.
The incorrect CAN node is enabled. Verify that Factory Settings 9000.001 -> 9031.001 are set correctly. Only active nodes should be enabled.
The Autodoor CAN PCB does not have power. Verify that the Low Volt Power supply is supplying power to the CAN Autodoor PCB.
The CAN node Communication cable is disconnected. Power down machine for at least a minute. Verify all CAN communication cables are connected correctly.
The CAN Module ID Selector is incorrect. Power down machine for at least a minute. Set ID selector correctly. Power up machine.
The CAN Modules have incorrect termination. Power down machine for at least a minute. Verify that only last node in the chain is terminated. Power up machine.
The CAN Node needs to be reset. Disable CAN Node via 9000.001 -> 9031.001. If the machine recovers (I/O page isn’t “X”) after disabling a particular node, try to enable the node again.
Alarm 9798: IOPCB CAN FCT CRC MISMATCH A test of the internal CRC for the Factory Config Table (FCT) located on one of the CAN devices does not match the CRC for the machines FCT. This can happen due to power failure at a critical time or after replacement of a CAN board attached to the I/O board
  1. Press [POWER OFF].
  2. Put the USB memory device into the control.
    Note: The USB memory device must contain your Haas Control Key and the correct configuration files.
  3. Press [POWER ON].
  4. Press [DIAGNOSTIC].
  5. Go to I/O Config in the Diagnostics tab.
  6. Press [F3] to Update Config Table.
  7. Press [RESET] to continue. If the alarm does not clear, cycle the machine power.
The Main CRC and the Factory CRC are now the same.
CAN code [0x43]: Invalid clamp value
Alarm 9706: Invalid clamp value
CAN code [0x43]
Outdated autodoor/Evise firmware Update the autodoor/evise to 1.06 or newer
CAN code [0x44]: Invalid voltage command
Alarm 9707: Invalid voltage command
CAN code [0x44]
Alarm 9899.001: CAN BUS OFF ERROR
Alarm 9700: CAN BUS OFF ERROR
Poor connection Verify CAN Bus Connetors are fully seated and termination resistor set correctly.
Short circuit on CAN Bus
Use multimeter to diagnose short circuit:
  1. Power down machine
  2. Disconnect all nodes
  3. Reconnect nodes one at a time while measuring resistance between CAN lines and 12V and Ground on the connectors
  4. Replace the node that results in a short circuit
Note: It should be 60 ohm between CAN-H and CAN-L
9899.002: CAN BUS OFF ERROR
CAN code [0x01]: Node reported it lost communication from I/O board
Alarm 9701: Node reported it lost communication from I/O board
CAN code [0x01]
CAN code [0x30]: I/O board reported it lost communication from node
Alarm 9702: I/O board reported it lost communication from node
CAN code [0x30]
I/O mapping missing node Verify in I/O Config tab that the node is mapped. Get the latest configuration from portal.
Incorrect node enabled Verify that Factory settings 9000.001 - 9031.001 are only set to true for the nodes that are installed in the machine.
Node ID set incorrectly on node Select correct node ID on ID selection switch. Reboot the machine.
Node lost power Use a multimeter to verify that the node has power. Replace the power supply if necessary.
Poor connection Verify that the CAN Bus Connectors are fully seated and that the termination resistor set correctly.
Alarm 9899.003: CAN BUS OFF ERROR
Alarm 9703: CAN NODE ERROR
Node Fatal alarm. Firmware has a non-recoverable alarm. Cycle node enable (90nn.001) or update config table in I/O page. The machine may need to be rebooted.
Alarm 9713: NODE APPLICATION CORRUPTED I/O Board has detected a CAN device with corrupted application&nbsp;firmware. Try updating the firmware for the affected CAN device.
Alarm 9714: NODE BOOTLOADER CORRUPTED I/O Board has detected a CAN device with corrupted bootloader firmware.
ALARM 966 EXCESSIVE TOOL IMBALANCE (board accelerometer) Excessive tool vibration is generated by on board accelerometer Verify that everything is properly balanced, such as tools and spindles
Reduce sensitivity using Setting 245
  • Setting 245 = Normal: Means that parameter 856 is directly used
  • Setting 245 = Low: Means that parameter 856 is multiplied by 1.5
  • Setting 245 = Off: Alarm 966 will not be thrown.
NOTE: Setting 245 will not persist when the power is cycled
Please refer to the  Accelerometer Troubleshooting Guide for further information
ALARM 9941 CRASH DETECTED (spindle head accelerometer)  The machine detected a crash Verify the program machine movements to make sure the machine does not crash
The Accelerometer unit, cable or spindle head CAN board is damaged
  • Verify analog inputs are not 0 (cable unplugged)
  • I/O board minimum version 4.09 (update to latest if possible)
  • Spindle head CAN board minimum 1.10 (update to latest if possible
  • Make sure to take an error report (SHIFT+F3), error reports will have information about the crash direction and magnitude in the JavaConsoleLog.txt file (refer to Crash Detection Section in the Accelerometer Troubleshooting Guide for further information)
Electrical Diagrams
CAN Bus sequence when a machine has Active Ballscrew Compensation, CAN E-Vise, Compact APL, Motion Sensor, and CAN Autodoor.
CAN Bus sequence when a machine has a CAN E-Vise, Compact APL, and CAN Autodoor.
The CAN Lube Panel and CAN Spindle Head PCB diagram with a CAN Autodoor and a CAN E-Vise
The CAN Lube Panel and CAN Spindle Head PCB diagram with a CAN Autodoor and without a CAN E-Vise
The CAN Lube Panel and CAN Spindle Head PCB diagram with a CAN E-Vise, but without a CAN Autodoor
The CAN Lube Panel and CAN Spindle Head PCB diagram without a CAN Autodoor or CAN E-Vise
Related Content
Smart CAN Autodoor TSG
CAN Lube Panel and Spindle Head TSG
DIagnostic Data
Firmware Update
I/O Troubleshooting
9.2 CAN Lube Panel and Spindle Head Troubleshooting Guide
CAN Lube Panel and Spindle Head - Troubleshooting Guide
TG0045
  • Each board has a node ID selection switch [SW2] that must be set correctly.
  • Devices are connected in Daisy Chain.
  • Each board has a termination switch [SW1] that much be set correctly.
Board Locations
Updated
Node ID Selection
IO Board 3 N/A
Alarm / CAN code
Before Software 100.21.000.1100
Alarm / CAN code
After Software 100.21.000.1100
Alarm 9105: IO BOARD COMMAND EXECUTION FAILURE
The machine outputs the following alarms with this alarm:
  • 2001.003: EMERGENCY STOP SWITCH ERROR
  • 2002: OPERATOR'S PENDANT EMERGENCY STOP SWITCH ERROR
  • 120: LOW AIR PRESSURE OR FLOW
Outdated main I/O firmware.
Updated the main I/O firmware to the latest version.
Refer to the Firmware Update procedure.
Alarm 9899 IOPCB CAN FAULT and/ or 9105 IO BOARD COMMAND EXECUTION FAILURE The CAN node I/O Configuration is incorrect. Update the I/O configuration via the I/O Config tab.
The Spindle Head or Lube Panel CAN PCB does not have power. Verify that the Low Volt Power supply is supplying power to the CAN Spindle Head or Lube Panel PCB.
CAN code [0x41]: Invalid command for motor 1
Alarm 9704: Invalid command for motor 1
CAN code [0x41]
TBD TBD
CAN code [0x42]: Invalid command for motor 2
Alarm 9705: Invalid command for motor 2
CAN code [0x42]
TBD TBD
CAN code [0x43]
CAN code [0x44]
CAN code [0x81]: Motor 1 shorted
or
CAN code [0x82]: Motor 2 shorted
Alarm 9708: Motor 1 shorted
CAN code [0x81]
or
Alarm 9709: Motor 2 shorted
CAN code [0x82]
Cable Failure Replace the motor cable.
Board Failure Replace the Autodoor/Evise board.
Motor Failure Replace the motor.
Alarm 9899.001: CAN BUS OFF ERROR Alarm 9700: CAN BUS OFF ERROR Poor connection Verify CAN Bus Connetors are fully seated and termination resistor set correctly.
Alarm 9899.002: CAN BUS OFF ERROR
CAN code [0x01]
CAN code [0x30]
Alarm 9899.003: CAN BUS OFF ERROR Alarm 9703: CAN BUS OFF ERROR Node Fatal alarm. Firmware has a non-recoverable alarm. Cycle node enable (90nn.001) or update config table in I/O page. The machine may need to be rebooted.
unrecognized CAN code
Alarm 9712: CAN NODE WARNING
TBD TBD
Alarm 9711: CAN BUS OFF ERROR
TBD TBD
Spindle Head & Lube Panel PCB Status LEDs
Spindle Head Status LED Locations
Lube Panel Satus LED Locations
PCB State Mode
Red LED
Green LED
Bootloader N/A
Off
On
Application Deactive (Node Disabled)
Off
Blinking 1 Hz
Active (Node Enabled)
Off
Blinking 2-5 Hz
Safe Mode
Blinking 2-5 Hz
Off
Dead Node
On
On
CAN Spindle Head & Lube Panel Troubleshooting
Problem: Machines with SW Version 100.21.000.1003 and earlier: Alarm 9899.002: Node ID: XX [0x30] IOPCB CAN FAULT or other 9899 CAN Bus alarms.
Machines with SW Version 100.21.000.1100 and later: Alarm 9702: I/O board reported it lost communication from node CAN code [0x30] or other CAN Bus alarms.
After cycle powering the machine, alarm 9105 IO BOARD COMMAND EXECUTION FAILURE is generated and other I/O & CAN alarms. Analog sensors all read zero.
Cause: Communication between the IO PCB and CAN bus PCB was lost. This can be caused by a communication interruption or because the CAN bus PCB or the CAN power supply has failed.
Update software, IO Firmware, and all CAN devices displayed that can be updated to the latest. If the node is damaged or disconnected it may not display on the list of nodes. All nodes are displayed on the Firmware Updates page[1]. The Spindle Head node is missing from the page[2], indicating that there may be an issue with that node.
After cycle powering with the E-Stop pressed, press reset to restore I/O PCB. Note any CAN or I/O alarms after pressing reset.
Navigate to the CAN Bus Diagnostic page. This requires a service key. Note the status of each node, do the faulted nodes correspond to the node displayed in the CAN alarm. Press F4 to Run Diagnostics.
If a single node at the end of the chain or in the middle of the chain is in a fault state, troubleshoot that PCB.
If two or more nodes are faulted, troubleshoot the first faulted node in the chain closest to the I/O PCB then move to the last.
Access the PCB and check the status lights. Spindle Head PCB LED location[1]. Lube Panel PCB LED location[2].
PCB State
Mode
Red LED
Green LED
Bootloader
N/A
Off
On
Application
Deactive (Node Disabled) - Fault State
Off
Blinking 1 Hz
Active (Node Enabled) - Normal State
Off
Blinking 2-5 Hz
Safe Mode - Fault State
Blinking 2-5 Hz
Off
Dead Node -  Fault State
On
On
If the Status LEDs are in a fault state, check the node ID selector and termination. If incorrect, power down the machine and change the node ID selector to the correct node ID and set the termination based on the machine configuration and the CAN devices installed on the machine.
With the machine powered down inspect the cables and disconnect and reconnect cables and CAN Bus couplers.
Power up the machine and check the CAN Bus page and press F4 to Run Diagnostics.
If the faulted nodes are the E-Vise or Auto Door, disable the node and verify that alarms clear.
Warning: Do not disable the Spindle Head or Lube Panel and run the machine. Damage or injury can occur.
Electrical Diagrams
Related Content
I/O Troubleshooting
DIagnostic Data
Firmware Update
CAN Bus Systems TSG
9.3 Compact APL Troubleshooting Guide
Compact APL - Troubleshooting Guide
TG0052
Revision A - 12/2025
Node ID Selection
IO Board 3 N/A
Alarm / CAN code
Alarm 17.9920/18.9920: POSITION ERROR TOO LARGE Electrical connections to the C-APL AV or AU servo amplifiers may be swapped.
Reference the C-APL electrical schematic below.
Alarm 9899: IOPCB CAN FAULT and/ or 9105: IO BOARD COMMAND EXECUTION FAILURE The CAN node I/O Configuration is incorrect. Update the I/O configuration via the I/O Config tab.
The CAN PCB does not have power. Verify that the Low Volt Power supply is supplying power to the CAN PCB.
Alarm 9704: CAN NODE INVALID COMMAND FOR MOTOR 1
CAN code [0x41]
Motor was commanded on in both directions simultaneously. If using Macro programming, verify G-Code is not turning on both outputs.
Alarm 9706: CAN NODE COMMANDED CURRENT OUT OF RANGE
CAN code [0x43]
Outdated CAN Board firmware. Update the CAN Board latest CAN firmware.
Alarm 9707: CAN NODE INVALID MAX VOLTAGE
CAN code [0x44]
Alarm 9708: CAN NODE MOTOR 1 SHORT DETECTED
CAN code [0x81]
Alarm 9701: CAN NODE LOST COMMUNICATION WITH IO
CAN code [0x01]
Alarm 9702: IO LOST COMMUNICATION WITH CAN NODE
CAN code [0x30]
Alarm 9703:
INTERNAL FAULT
When trying to run the machine a yellow warning message appears saying "Please activate Light Curtain or Cell Safe". The correct safety parameter kit has not been applied to the machine. Order the corresponding Front Automation Safety or Side Automation Safety kits (93-1000997 or 93-1000996) and re-upload the configuration files from HBC.
AU axis noisy when the APL moves AU axis coupler not attached correctly. Realign the coupler to the motor and ballscrew. Reset the grid offset once this is done.
AU axis coupler is fractured.  The AU axis coupler will need to be replaced. Once the new coupler has been replaced and aligned, reset the grid offset for the AU axis.
Electrical Diagrams
Compact APL Electrical Schematic
Related Content
I/O Troubleshooting
DIagnostic Data
Firmware Update
CAN Bus Systems TSG
9.4 Autodoor
Autodoor - Service Manual
Click on the image below to take you to the Autodoor - Service Manual
9.5 Active Ballscrew Compensation Troubleshooting Guide
Active Ballscrew Compensation - Troubleshooting Guide
TG0025
Overview
The Active Ballscrew Compensation is made up of:
  1. Linear Gauge Sensor - The sensor assembly is installed at the end of the ballscrew.
  2. CAN Node Box - CAN node box that feeds the information from the sensor to the CAN hub board.
  3. Linear Gauge Hub Board -CAN board the sends feedback info from the sensor to the IO board.
Each Axis will have its own Linear Gauge Sensor [1] and CAN Node Box [2] that will connect to the CAN Hub Board [3].
The cables coming from each of the axis' CAN Node Box will connect to the following ports on the CAN Hub Board:
  • X-Axis: Sensor 1 Port
  • Y-Axis: Sensor 2 Port
  • Z-Axis: Sensor 3 Port
At this time Active Ballscrew Compensation is an option on the following machines and their variants:
  • VF-6/7/8/9/10/11/12/14
  • VR-8/9/11/14
  • VM-6
Node ID Selection
IO Board 3 N/A
Alarm / CAN code
Cannot upgrade the CAN board firmware. The I/O board has a firmware version earlier than 4.24. Upgrade the I/O firmware to 4.24 or higher. Try upgrading the CAN board firmware after the I/O firmware is upgraded.
Alarm 9417: LINEAR SENSOR FAULT DETECTED Invalid reading from linear sensor has been detected. The sensor may be disconnected. Verify all hardware connections are secure and correct Refer to the Overview section above for all the components in the system, the wiring diagram can be found below for where it lies within the CAN system.
The CAN node Communication cable is disconnected. Power down the machine for at least a minute. Verify all CAN communication cables are connected correctly.
The CAN Module ID Selector is incorrect. Power down the machine for at least a minute. Set ID selector correctly. Power up machine.
The CAN Modules have incorrect termination. Power down the machine for at least a minute. Verify that only the last node in the chain is terminated. Power up machine.
The CAN Node needs to be reset. Disable CAN Node via 9000.001 -> 9031.001. If the machine recovers (I/O page is not “X”) after disabling a particular node, try to enable the node again.
CAN code [0x01]
Poor connection  Verify CAN Bus Connectors are fully seated, and termination resistor set correctly.
CAN code [0x30]
Poor connection Verify that the CAN Bus Connectors are fully seated, and that the termination resistor set correctly.
Alarm 9703:
CAN NODE ERROR
Alarm 9737.00X: Linear Sensor Error
Sub-codes:
.001 = X-Axis
.002 = Y-Axis
.003 = Z-Axis
The sensor node has lost communication with the linear sensor. This may be due to a faulty sensor or loose connection to the Node.
1. Verify the cable connection of the linear sensor to the node.
2. Under the diagnostics tab, navigate to the I/O page, and check the analog input for the axis generating the alarm.
  • A-Input 27 = X-axis
  • A-Input 28 = Y-axis
  • A-Input 31 = Z-axis
3. If possible, apply pressure to the switch by hand to see if the analog value increases as the switch is pushed in. Verify the input is not constantly 0.
4. Also verify that the input is not fluctuating when a constant/no pressure is applied to the switch.
Wiring Diagram
CAN Bus sequence when a machine has a Ballscrew Linear Sensor, CAN E-Vise, Compact APL, and CAN Autodoor.
