5 - CAN Bus Systems - CAN Lube Panel and Spindle Head
CAN Bus Systems - Service Manual
  • 1 - CAN Bus Systems - Introduction
  • 2 - CAN Bus Systems - Diagnostics
  • 3 - CAN Systems - Autodoor
  • 4 - CAN Bus Systems - E-Vise
  • 5 - CAN Bus Systems - CAN Lube Panel and Spindle Head
  • 6 - CAN Bus Systems - Compact APL
  • 7 - CAN Bus Systems - Active Ballscrew Compensation
  • 8 - Can Systems - Motion Sensor
  • 9 - CAN Bus Systems - Troubleshooting
  • 5.1 CAN Lube Panel and Spindle Head PCB - Replacement
  • 5.2 CAN Sindle Head Bracket - Replacement
AD0560
Revision A - 05/2025
This procedure tells you how to replace the CAN boards in the lube panel and the spindle head in mills and lathes.
This procedure applies to the following service kits:
  • 93-32-0916: SVCKIT CAN SPINDLE HEAD ASSY MILL
  • 93-32-0913: SVCKIT CAN SPINDLE HEAD ASSY LATHE
  • 93-32-0884: SVCKIT CAN LUBE PANEL ASSY
Removal
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Spindle Head Board
Remove the cover [1] in the spindle head.
Remove the bracket [2], board, and screws.
The cover and bracket can be found where shown at [3] for mills, at [4] for UMCs, and at [5] for lathes.
Note: Keep the cover, as it will be reused later.
Lube Panel Board
Remove the hardware [1] to remove the bracket and cover [3] from the lube panel.
Remove the hardware [2] and cover from the bracket [3].
Remove the hardware [6] and board [5] from the bracket.
Note: Only the board will be replaced, keep the existing bracket, cover, and hardware to reuse later.
Replacement
Spindle Head Board
Note: Connect the CAN communication cable to the board before mounting as it will be inaccessible when mounted.
Mount the new board [3] and bracket [2] with the hardware provided at the same location the previous one was removed from.
Install the cover [1].
Lube Panel Board
Attach the new board [1] to the existing bracket [3] using the existing hardware [2].
Attach the cover to the bracket [4] using the existing hardware [5].
Attach the assembly to the lube panel with exiting hardware [6].
The lube panel pcb contains several inputs and outputs that are labeled as "spare".
The spare inputs [1] labeled S1 - S6 and the spare outputs [2] are not available for general purpose use.
Note: These inputs and outputs are included on machines so that they can be utilized when future machine options are created that way the Lube Panel PCB does not have to be replaced.
Electrical Diagrams
The CAN Lube Panel and CAN Spindle Head PCB diagram with a CAN Autodoor and a CAN E-Vise
The CAN Lube Panel and CAN Spindle Head PCB diagram with a CAN Autodoor and without a CAN E-Vise
The CAN Lube Panel and CAN Spindle Head PCB diagram with a CAN E-Vise, but without a CAN Autodoor
The CAN Lube Panel and CAN Spindle Head PCB diagram without a CAN Autodoor or CAN E-Vise
5.2 CAN Spindle head Bracket-Replacement
CAN Spindle Head Bracket - Replacement
AD0971
Revision A - 05/2026
This document provides instructions for replacing the CAN SPHD Bracket 28-0448 within the following subassemblies.
  • 32-1377 CAN SPNDL HEAD ASSY - MILL
  • 32-1647 CAN SPNDL HEAD ASSY - LATHE
This replacement kit 93-6348 is designed to solve the issue of plastic bracket fatigue caused by repeated removal and re-installation of the cover. The updated 28-0448A bracket incorporates 8-32 threaded inserts for cover attachment, providing a more durable and reliable mounting solution.
Kit Includes:
  • CAN ELECT SPHD PLASTIC BRKT W 8-32 INSRT
  • GASKET CAN SPHD ASSY
  • PPHS 8-32 X 1/2
  • PPHS 6-19 X 5/16 THREAD FORMING
Note: Both the original and replacement brackets require cover installation and removal using hand tools only. Power tools must not be used.
Replacement Procedure
Disassembly:
Remove 3x PPHS 8-32 x ½ [1] from front of assembly.
Remove 2x SHCS 10-32 x 3/8 [5] from front of bracket [3].
Remove 4x PPHS 6-19x5/16 [4] to disconnect the PCB from bracket [3].
Installation:
Install new GASKET CAN SPHD ASSY [2] and new CAN ELECT SPHD PLASTIC BRKT W 8-32 INSRT.
Install new 4x PPHS 6-19 x 5/16 THREAD FORMING screws [4] to attach PCB to bracket.
Reinstall 2x SHCS 10-32 x 3/8 [5].
Install new 3x PPHS 8-32 x ½ [1].
