1 - CAN Bus Systems - Introduction
CAN Bus Systems - Service Manual
  • 1 - CAN Bus Systems - Introduction
  • 2 - CAN Bus Systems - Diagnostics
  • 3 - CAN Systems - Autodoor
  • 4 - CAN Bus Systems - E-Vise
  • 5 - CAN Bus Systems - CAN Lube Panel and Spindle Head
  • 6 - CAN Bus Systems - Compact APL
  • 7 - CAN Bus Systems - Active Ballscrew Compensation
  • 8 - Can Systems - Motion Sensor
  • 9 - CAN Bus Systems - Troubleshooting
  • 1.1 Introduction
1.1 Introduction
Overview
Controller Area Network (CAN) is a robust vehicle bus standard designed to allow microcontrollers and devices to communicate with each other. This method is used to create satellite nodes grouped by function that can be expanded on without changing the core electronics.
Each board has a node ID selection switch [SW2] that must be set correctly.
Devices are connected in Daisy Chain.
Each board has a termination switch [SW1] that much be set correctly.
Note: The last device on the chain needs to be terminated.
Disclaimer
Only a certified technician is allowed to repair this machine.
All information provided for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only services and repairs provided by authorized Haas Factory Outlet technician are guaranteed.
Only an authorized Haas Factory Outlet distributor should service or repair a Haas machine that is protected by the original factory warranty. Servicing by any other party voids the warranty.
