7 - CAN Bus Systems - Active Ballscrew Compensation
CAN Bus Systems - Service Manual
  • 1 - CAN Bus Systems - Introduction
  • 2 - CAN Bus Systems - Diagnostics
  • 3 - CAN Systems - Autodoor
  • 4 - CAN Bus Systems - E-Vise
  • 5 - CAN Bus Systems - CAN Lube Panel and Spindle Head
  • 6 - CAN Bus Systems - Compact APL
  • 7 - CAN Bus Systems - Active Ballscrew Compensation
  • 8 - Can Systems - Motion Sensor
  • 9 - CAN Bus Systems - Troubleshooting
  • 7.1 Active Ballscrew Compensation - Overview
  • 7.2 Active Ballscrew Compensation - Replacement Kits
  • 7.3 Active Ballscrew Compensation - Calibration
Overview
At this time Active Ballscrew Compensation is an option on the following machines and their variants:
  • VF-6/7/8/9/10/11/12/14
  • VR-8/9/11/14
  • VM-6
Note: The Active Ballscrew Compensation linear sensor is not a field installable option at this time.
Minimum Software Version for Active Ballscrew Compensation is 100.23.000.1110.
IMPORTANT: If the machine with Active Ballscrew Compensation has software version 100.24.000.1000 or higher, the I/O Firmware must be 4.24 or higher.
Active Ballscrew Compensation improves the dynamic and absolute positioning accuracy along  the machine’s linear axes, by measuring changes in the length of a ballscrew, and continuously compensating for thermal variations. This real-time, closed-loop feedback system works well for continuous motion, such as 3D surfacing and interpolation.
Large systems have many long and large components that react to changes in temperature more easily. Active Ballscrew Compensation helps correct for this variation, and is ideal for locations that experience large temperature changes.
The Active Ballscrew Compensation is made up of:
  1. Linear Gauge Sensor - The sensor assembly is installed at the end of the ballscrew.
  2. CAN Node Box - CAN node box that feeds the information from the sensor to the CAN hub board.
  3. Linear Gauge Hub Board -CAN board the sends feedback info from the sensor to the IO board.
Each Axis will have its own Linear Gauge Sensor [1] and CAN Node Box [2] that will connect to the CAN Hub Board [3].
The cables coming from each of the axis' CAN Node Box will connect to the following ports on the CAN Hub Board:
  • X-Axis: Sensor 1 Port
  • Y-Axis: Sensor 2 Port
  • Z-Axis: Sensor 3 Port
AD0713
This procedure outlines how to replace the different aspects of the linear gage sensor for the Active Ballscrew Compensation.
This procedure applies to the follow service kits:
  1. 93-3886: BSCREW LINEAR GAGE MECH ASSY SVC KIT
  2. 93-3816: SVC KIT LINEAR GAUGE NODE ASSY
  3. 93-32-2005: SVC KIT LINEAR GAUGE HUB
Linear Sensor Assembly Replacement
Use this section when replacing the Linear Sensor Assembly from service kit 93-3886.
Remove the cover and its hardware [1]. Save these parts as they will be reused after the replacement.
Unplug the linear sensor cable [2] from the node box.
Remove the bolts and washers [3] that are holding the linear sensor assembly in place. Save the hardware as they will need to be reused.
Once the bolts are out, remove the linear gage assembly [4].
To replace the steel ball [1] in the ballscrew center, apply a pea-size drop of tacky grease in the ballscrew center and insert the steel ball ensuring the grease holds it in place.
Take the linear sensor assembly from the service kit and place it where the old one was removed from [1].
Secure the linear sensor assembly by reinstalling the bolts and washers [2], verify the ball and tip of the linear sensor are making contact and torque the bolts to 25 ft-lbs.
Reconnect the linear sensor cable [3] to the node box.
Install the cover [4] back onto the bracket.
CAN Node Box Replacement
Use this section when replacing the CAN Node Box from service kit 93-3816.
Disconnect the sensor cable [3] and hub cable [4] from the node box [2].
Remove the bolts [1] and node box assembly [2] from the casting.
Remove the bolts [5] and sheet metal bracket [6] from the node box.
Important: Keep the hardware and bracket that was removed to use with the new node box.
Install the node box bracket [2] using its hardware [1] onto the new node box.
Attach the new node box assembly [4] with the old hardware [3].
Connect the linear sensor cable [5] and hub cable [6] to the node box [4].
Follow this step for the Node Box location on the X-Axis
The CAN Node Box location will be on the right side of the saddle, the exact location is machine dependant:
  1. VF-6/8
  2. VF-7/9
  3. VF-10/11
  4. VF-12/14
Follow this step for the Node Box location on the Y and Z Axes
The Y-Axis CAN Node Box will be towards the front of the base on the right side of the ballscrew [1].
The Z-Axis CAN Node Box will be towards the bottom of the column on the right side of the ballscrew [2].
Linear Gauge Hub Board Replacement
Use this section when replacing the Linear Gage Hub Board from service kit 93-32-2005.
To replace the Hub Board, disconnect the cables and remove the old board [1].
Install the new board [1] the same as the old and reconnect the cables.
Refer to the Active Ballscrew Compensation - Troubleshooting Guide for the wiring diagram if needed.
Calibration
After any part has been replaced, refer to the Active Ballscrew Compensation - Calibration procedure and calibrate the axis that had the replacment.
This procedure outlines how to calibrate the Active Ballscrew Compensation system.
Note: The system should be calibrated only after the machine has been idle for at least 5 hours so that the axis ballscrew is at room temperature.
A calibration should be done after any linear sensor part or ballscrew is replaced.
Important: It is recommended to run a calibration at machine install.
Calibration
Verify the linear sensor is enabled for each axis it is installed on, it should be set to SCALE_DELTA [1].
Note: This image shows all three axes enabled, only the axes that have the linear sensor should be enabled.
Perform the following steps for every axis with a linear sensor that needs calibration
  1. Navigate to the Factory Tab [1] under Diagnostic > Parameters.
  2. Search .364 [2] in the Factory Tab.
  3. Type in the Axis Letter and press F2 [3].
  4. A pop up [4] will show up asking if you would like to calibrate the linear sensor offset, press [Y].
After the axis has been calibrated the offset value will show up in the parameters [5].
