C-Axis - Test Procedure - Lathe
Service Home How To Procedures C-Axis - Test Procedure - Lathe
Recently Updated Last updated: 11/27/2018
C Axis - Test Procedure - Lathe
Applies to machines built from: August, 2013
- Jump to Section - 1. Test Procedure (1 step) Back to Top
Test Procedure
This procedure tells you how to test the C Axis option. Before this test make sure to do the ST/SL Lathe - C Grid Offset Adjustment and the ST/SL Lathe - C Axis Gear Mesh Contact Load Adjustment.
Run the following program in MDI Mode:
M154;
M155;
M99;
Press [RESET].
Press [CYCLE START].
The machine should orient the spindle, and engage the C Axis without fault.
If the machine displays an alarm, check the ST/SL Lathe - C Grid Offset Adjustment, ST/SL Lathe - C Axis Gear Mesh Contact Load Adjustment and the spindle encoder pulley.
