Lathe - Front Skirt - Replacement - AD0705
Service Home How To Procedures Lathe - Front Skirt - Replacement - AD0705
Recently Updated Last updated: 10/20/2023
AD0705
- Jump to Section - 1. Introduction 2. Replacement (9 steps) Back to Top
This procedure shows how to replace a front skirt for the lathes listed below.
Machine Compatibility:
  • ST-20/L/Y/LY
  • ST-30/L/Y/LY
  • 93-3931 FRONT SKIRT REPLACEMENT KIT ST-20/Y
  • 93-3932 FRONT SKIRT REPLACEMENT KIT ST-20L/LY
  • 93-3875 FRONT SKIRT REPLACEMENT KIT ST-30/Y
  • 93-3933 FRONT SKIRT REPLACEMENT KIT ST-30L/LY
Tools Required:
  • RTV 108 (P/N: 93-99-4465)
Replacement
Note: The ST-30L is shown for reference. The same applies for the ST-30/Y/LY and ST-20/L/Y/LY unless mentioned otherwise.
Press [POWER OFF].
Remove the enclosure door rail panel [1].
Remove the lower side panel [1].
Remove the bolts [2] holding the HPU manifold [3] to the front skirt.
Note: Be sure to hold the HPU manifold while separating it from the front skirt to prevent it from falling.
Use a block [4] to support the sheet metal holding the HPU before removing the front skirt.
If the machine is equipped with a washdown hose, disconnect it before removing the front skirt.
Remove the front skirt [1]. Leaving the front lower brackets [2] on the machine.
Drill a .344" hole [1] in the location shown on the sheet metal [2] holding the HPU.
Install the magnets [1] onto the back of the new front skirt [2].
Install the front skirt [1] onto the machine.
Note: Once the front skirt is installed, the block supporting the sheet metal from step 2 can be removed.
Install [1] the HPU manifold [2] onto the front skirt.
If machine is equipped with a washdown hose, reconnect it to the front skirt.
Install the lower side panel [3].
Install the enclosure door rail panel [1].
If the machine does not have a washdown hose, install plugs [1] into washdown holes.
If the plugs are loose, apply RTV 108 to reduce movement.
