Multi-Stage Coolant Pump - Replace Gasket
Service Home How To Procedures Multi-Stage Coolant Pump - Replace Gasket - AD0914
24.3 Multi-stage Coolant Pump - Replace Gasket
Recently Updated Last updated: 11/10/2025
Multi-Stage Pump - Replace Gasket
AD0914
Revision A - 11/2025
This procedure demonstrates how to replace the gasket on a multi-stage pump. This procedure is compatible with 93-5645 Gasket Replacement Kit.
Replace Gasket - Multistage Pump
Unbolt pump from pump stand.
Loosen the bolts [1] and remove the fan cover.
Use a flathead screwdriver or other method to pry the fan off of the motor [1].
Loosen the nuts [1] and remove the clamps holding the stages in place.
Loosen the retaining nut on the bottom of the pump shaft. Disassemble the pump stages. Keep track of the order that the impellers, spacers, and covers were removed.
 Note: These stages will need to be replaced in the correct order after the gasket replacement is complete.
Remove broken gasket. Wipe gasket seat to remove any coolant or debris [1]. Replace the gasket on gasket seat. Re-install the pump stages, taking care to replace all components in the correct order.
Re-assemble pump and run coolant to ensure leaking is resolved.
