Multi-Stage Coolant Pump - Installation - AD0856
Service Home How To Procedures Multi-Stage Coolant Pump - Installation - AD0856
24.2 Multi-Stage Coolant Pump - Installation
Recently Updated Last updated: 10/24/2025
AD0856
Revision A - 09/2025
This procedure documents how to install the Multi-Stage Pump.
Note: The Multi-Stage Pump is not compatible with the auxiliary filter or Variable Flow Coolant (VFD) options. Do not connect Multi-Stage Pump to auxiliary filter tank or VFD.
  • 93-4839 Multi Stage Coolant Pump Assembly
  • 93-1001166 Multi Stage Field Install Kit
 Note: 93-1001166 Multi Stage Field Install Kit is only for upgrading from a Single-Stage 3-phase coolant pump (Motor PN: 30-14261) to the Multi-Stage Coolant Pump.
The Multi-Stage Pump is compatible with the following machines:
  • VF-S/M/L
  • VM
  • VP-5
  • UMC-500/750/1000/1250/1500-Duo
  • ST-10/15/20/25/28/30/35/L/Y
  • ST-40/45/Y
  • ST-40S/Y
  • ST-40/45/L/Y Reboot
  • HDC-3-5AX
  • VS-1/3
Note: This procedure is being shown on a VF machine. The procedure applies to all machines listed.
Multi-Stage Pump Installation
Power off the machine.
Disconnect power cord and coolant hose from old coolant pump. Remove coolant pump.
Note: Do not discard coolant hose. It will be re-used for the multi-stage pump.
Install multi-stage pump.
Re-connect coolant hose [1]. Connect coolant pump power cable to plug labeled 'Low Pressure Coolant' [2].
Verification
Power up machine. Run coolant for several minutes and check system for leaks.
