Origin Switch DT/DM - Replacement
Service Home How To Procedures Origin Switch DT/DM - Replacement
Recently Updated Last updated: 04/16/2020
- Jump to Section - 1. Introduction 2.  (5 steps) Back to Top
This procedure will show how to replace the origin switch [1] on the DT/DM series.
Remove the sheet metal [1] & [2]  that covers the tool changer and the top cover.
Remove the carosel [1] from the machine, you may do so by removing these bolts attached to the mount [2].
Replace the origin switch and reassemble the DT/DM in the reverse order of these steps.
If you are replacing an adjustable switch go to step 4.
Double arm grid offset
If you are replacing an adjustable origin switch you will need to do so off the diagnostic page, use the link to complete this step.
SMTC Double Arm - Replacement
SMTC Z-Axis Tool Change Offset - Parameter 64 - DT-1
Use the links to align the tool changer arm and set the Z-axis Tool height parameter.
