    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
DT/DM - SMTC - Z-Axis Tool Change Offset - Parameter 64
Service Home How To Procedures DT/DM - SMTC - Z-Axis Tool Change Offset - Parameter 64
Recently Updated Last updated: 10/25/2022
- Jump to Section - 1. DT-1 - Side-Mount Tool Changer - Z-Axis Tool Change Offset - Parameter 64 (5 steps) Back to Top
Push [ZERO RETURN]. Push [Z]. Push [SINGLE].
Go into DEBUG mode.
Put a tool holder [1] in tool pocket 1 of the carousel.
Jog the X Axis to move the table [2] under tool pocket 1.
Put the tip of a 0.0005" indicator [1] on the bottom surface of the tool.
Set the indicator to 0.
Jog the X Axis to move the indicator away from the tool pocket 1.
Remove the tool holder [2] from the tool pocket.
 Caution: Do not move the indicator.
Install the tool holder [1] into the spindle.
 Caution: Be careful not to move the position of the magnetic base [3] of the indicator.
Jog the X and Y Axes until the indicator tip [2] is under the tool holder.
Jog the Z Axis in the negative (-) direction.
Repeat until following conditions are true:
  • The tool holder touches the indicator tip.
  • The indicator dial shows 0.
Push [POSITION].
Record the Z COMMAND value.
Subtract the Z COMMAND value from Parameter 64.
Push [ZERO RETURN]. Push [Z]. Then push [SINGLE].
Jog the X Axis to move the indicator [1] away from the tool holder.
 Caution: Before you push [HOME G28]. Keep one hand above [EMERGENCY STOP]. Be prepared to push [EMERGENCY STOP] if the Z Aaxis travels too far.
Push [5% RAPID]. Push [Z]. Then push [HOME G28].
Jog the X Axis to move the indicator [1] under the tool holder.
Repeat this procedure until the indicator shows less than 0.001" (0.03 mm)
Remove the tool holder [2] from the spindle.
Command several tool changes to test the tool changer operation.
 Note: After doing the procedure, reset the tool length offsets.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
