Servo-Driven SMTC - Double Arm Grid Offset and Tool Changer Offset - NGC
Service Home How To Procedures Servo-Driven SMTC - Double Arm Grid Offset and Tool Changer Offset - NGC
6.7 Servo-Driven SMTC - Double Arm Grid Offset and Tool Changer Offset - NGC
Recently Updated Last updated: 08/13/2025
Revision B - 08/2025
This procedure tells you how to reset the double arm grid offset and tool changer offset.
Note: In software version 100.17.000.1037 and later the TA axis is now the tool arm axis. Refer to the Next Generation Control - Axis Assignments procedure.
 NOTE:  This procedure can only be performed by a Haas certified service technician.
Tools Required:
  • Haas Control Key
NGC - Servo-Driven SMTC - Double Arm Grid Offset and Tool Changer Offset
Power on the machine with your Haas Control Key.
Go to DIAGNOSTIC>FACTORY tab.
Press E-STOP.
Set parameters 11.078 and 11.140 to zero.
Release E-STOP and press [RESET].
Press [ZERO RETURN] and ALL.
Press [RECOVER], and [Y] to continue.
Press [M] for manual recovery mode [1].
Press ▼ to advance the TC arm until it first reads home.
Note: The home position should be reached within 0 to 15 degrees. Jogging the arm too far can crash into the spindle head if the Z-axis isn't homed.
 Important: Verify that the pocket is in the up position before exiting recovery.
Press [E] to exit recovery.
Enter the DIAGNOSTICS>FACTORY tab.
Type [TA] and press [F4] and then [Y] for yes.
A value for parameter 11.140 should populate.
Press [ZERO RETURN] and [ALL].
Press [RECOVER] and [Y] for yes.
Enter [M] manual mode again.
Note that the arm will read off position again.
Press ▼ until the double arm reads home [1].
Take note of the first arm position to read home.
  • I.e. 5.000 in [1].
Press ▼ until the double arm reads off position [2] then press ▲ once.
Take note of the last arm position to read home.
  • I.e. 13.000 in [3].
Add the two arm positions and divide by 2 to find the center.
  • Example:
5.000 + 13.000 = 18.000
18.000 ÷ 2 = 9.000
Multiple by -1.
  • Example:
9.000 x -1 = -9.000
Leave the arm at a position reading home. Press [E] to exit.
Go to the DIAGNOSTICS>FACTORY tab.
Press E-STOP.
Enter the value calculated in the previous step to parameter 11.078.
  • I.e. -9.000
  • Follow the SMTC - Spindle Orientation Offset procedure to verify the spindle orentation.
  • Perform a few tool changes to verify eveything works correctly.
