Reformat USB Flash Drive to FAT32 for Haas Control - NGC
Service Home How To Procedures Reformat USB Flash Drive to FAT32 for Haas Control - NGC
Recently Updated Last updated: 10/14/2025
Revision A - 10/2025
- Jump to Section - 1. Introduction 2. Option 1: Windows Powershell (2 steps) 3. Option 2: Using Rufus 4. Option 3: Windows File Explorer (2 steps) 5. Checking File Format Back to Top
The Haas Next Generation Control supports the FAT32 file system for USB flash drives. Some USB flash drive manufacturers do not format drives larger than 32GB with the FAT32 file system. On Windows, the option to format USB flash drives larger than 32GB with FAT32 file system is not available in the Windows File Explorer. Therefore, it is necessary to format the USB flash drive to use the FAT32 file system using other software utilities.
Note: Machines using 19-inch software (100.25.001.1000 and higher) can use USB sticks formatted with exFAT. Software Revision Numbers - NGC
Notice: The instructions provided in this document are for reference only. Haas Automation, Inc. does not endorse or guarantee the quality of any third-party software referenced in this guide. Please contact your IT service professional for any specific troubleshooting procedures.
Warning: The following guides involve formatting the USB flash drive’s file system. The USB flash drive data will be erased. Please backup any data that you would like to keep. Haas Automation, Inc. is not responsible for any incurred data loss.
Press Windows + X command to open a menu:
Select the option “Command Prompt (Admin)” to open an Administrator Command Prompt:
In the command console, type ‘powershell’ to run the PowerShell utility:
At the PowerShell prompt, type the following command:
Note: X is the drive letter of the USB flash drive you want to format.
format /FS:FAT32 X:
Wait for the format operation to complete. This may take several minutes to complete:
Go to: https://rufus.ie/
Download Rufus and Run the utility.
In the Device select the USB device [1].
In the Boot selection  select Non bootable [2].
In the File System select FAT32 (Default) [3].
Select Start [4] button a prompt will appear.  Press OK to continue.
Wait for the operation to complete.  This may take several minutes.
Plug the USB stick into a PC and open File Explorer. Right click on the drive and select "Format" [1].
Select FAT32 or exFAT [1] in the dropdown.
Then press "Start" [2] to reformat the drive.
To check the format of a USB stick, insert it into a computer and open File Explorer. Right-click on the USB drive and select properties [1].
The file format will be listed [2].
