Remote Quill Switch - Installation - AD0505
Service Home How To Procedures Remote Quill Switch - Installation - AD0505
Recently Updated Last updated: 07/17/2020
AD0505
- Jump to Section - 1. Introduction 2. Installation Back to Top
The Remote Quill Switch is used in conjunction with a Servo Control and (Indexer/Rotary Table) on a manually operated “Knee Mill” to index a part automatically rather than manually hitting the “Cycle Start” button time after time.
This is accomplished by placing the remote quill switch at the top of the quill’s travel causing the switch to engage when the drilling has been completed and the quill retracted to the top of it’s travel. This will signal the indexer to index to the next step in the program.
RQS    Remote Quill Switch
1.       Plug the RQS into the mating connector (4 pin Din connector) on the back panel of the Servo Controller.
2.       Once the switch is connected to the controller you can verify the operation of the switch via a simple test program. With the control turned on and “homed” depress the quill switch to verify the indexer moves to the next step.
3.       Install switch on Mill making sure the switch comes in contact with the “jam nut”.
IMPORTANT: The control normally positioned away from work area.
