RPL - Zero Point Clamp - Replacement - AD0902
Service Home How To Procedures RPL - Zero Point Clamp - Replacement - AD0902
11.6 RPL - Zero Point Clamp- Replacement
Recently Updated Last updated: 08/15/2025
AD0902
Revision A - 08/2025
The instructions below will show you how to replace the Zero Point Clamp on your zero point for your RPL.
The following procedure applies to these kits:
  • 93-4836 ZERO PT CLAMP 130MM OD REPLACEMENT
Zero Point Clamp - Removal
Remove the zero point clamp assembly [1] by removing the bolts on the top face.
Note: When removing the zero point clamp from the receiver, be careful not to lose any of the O-rings located on its underside. These are essential for proper sealing and function.
Zero Point Clamp - Installation
Turn the clamp assembly upside down.
Use dielectric grease to install the 3 O-rings onto the clamp assembly.
Install the smallest O-ring on the clamp port [1].
Install the large O-ring [2] and the medium O-ring [3] onto the clamp assembly as shown in the image.
Install the clamp assembly [1] onto the zero point receiver [2].
Make sure that the clamp port [3] is aligned with the port on the pallet receiver plate [4].
Note: Ensure the clamp port is properly aligned. Misalignment will prevent the zero point from clamping or unclamping correctly, potentially causing operational issues.
