Spindle Motor Alignment - EC-400 - AD0463
Service Home How To Procedures Spindle Motor Alignment - EC-400
Recently Updated Last updated: 10/14/2019
AD0463
- Jump to Section - 1. Introduction 2. Spindle Motor Alignment - EC-400 (3 steps) Back to Top
Follow this procedure whenever a spindle is loosened or replaced, a TRP is replaced, or a spindle motor is loosened or replaced.
A spring scale is used to support the weight of the spindle motor to allow it to “float” for alignment.
Remove the spindle motor fan assembly [1] from the spindle head.
Jog the spindle head up so that the spring scale T-0127 [1] can be installed onto the eye bolt at the top of the spindle column [2] and the hole in the sheet metal motor lift bracket [3].
Loosen the (4) motor mounting bolts [1] until the the washers can be rotated freely.
Slowly jog the spindle head down until the spring scale [2] reads 125 lbs.
Operate the spindle at 800 RPM tighten the motor mounting bolts to prevent the motor from shifting.
Torque the motor mounting bolts in a star pattern.
