ST-10 - 30 Bulkhead - Brass Wiper Replacement - AD0677
Service Home How To Procedures ST-10 - 30 Bulkhead - Brass Wiper Replacement - AD0677
Recently Updated Last updated: 04/17/2023
AD0677
- Jump to Section - 1. Introduction 2. Removal (2 steps) 3. Installation (2 steps) Back to Top
This procedure tells you how to replace the bulkhead brass wipers on ST-10 to 30 series machines.
The following service kits apply to this procedure:
  • 93-3777 ST-10/15 BULK HEAD COVER/BRASS WIPER KIT
  • 93-3778 ST-20/30 BULK HEAD BRASS WIPER KIT 2022
  • 93-3779 ST-20/30 BULK HEAD BRASS WIPER KIT PRE 2022
Removal
Jog the axes into a position where the brass wipers are easily accessible.
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Remove the screws securing both sections of the metal waycover [2] and brass wipers [1] to the enclosure.
Remove both waycover [2] and wipers [1]. Disregard both.
Install the screws securing both sections of the brass wipers [1] and metal waycover [2] to the enclosure.
NOTE: Secure both ends of the wiper assembly first and then secure the middle of the wiper assembly for a more uniform installation.
IMPORTANT: Make sure brass wipers [1] make full contact with the enclosure with no gaps present.
Unlock the main circuit breaker. Set the main circuit breaker to the ON position.
Push [POWER ON].
Check the movement to make sure the waycover does not bind.
