ST-20/30/L - Two Piece B-Axis Cover - Replacement - AD0755
Service Home How To Procedures ST-20/30/L - Two Piece B-Axis Cover - Replacement - AD0755
- Jump to Section - 1. Introduction 2. Installation (4 steps) Back to Top
Recently Updated Last updated: 04/04/2024
AD0755
This procedure will show you how to replace the B-Axis cover with the two piece B-Axis cover for the Ball/ACME Screw.
  • 93-4567: B-AXIS COVER SERVICE KIT ST-20
  • 93-4565: B-AXIS COVER SERVICE KIT ST-20L
  • 93-4566: B-AXIS COVER SERVICE KIT ST-30
  • 93-4564: B-AXIS COVER SERVICE KIT ST-30L
Remove the access panel [1].
Jog the B-axis to its middle travel so that the B-axis cover screws are accessible and press [E-STOP].
1. Remove the hardware from the motor end side by accessing through the front door.
2. Remove the hardware on the support end side by accessing the access panel that was removed on the chip conveyor side.
Slide out the B-axis cover.
Use the (2) screws to install the B-axis cover [1].
If the support housing cover is not already screwed on to the ballscrew cover, then install the support housing cover [2] using the (2) screws [3] to the Ballscrew Cover Mount and then the (2) screws [4] to the B-axis cover.
Install the access panel [1].
