ST-40/45/50/55 - Pendant - Installation - AD0175
Service Home How To Procedures ST-40/45/50/55 - Pendant - Installation
Recently Updated Last updated: 09/23/2020
AD0175
Applies to machines built from: February, 2015
- Jump to Section - 1. Installation (6 steps) Back to Top
This procedure is for the ST-40/45/50/55 lathe. These machines ship without the storage cabinet and control pendant installed. This procedure tells you how to install the storage cabinet and control pendant.
Attach the storage cabinet [2] to the right door.
Push the pendant cables [1] to the left side of the cabinet.
Attach the air gun holster [2] to the tool rack [3].
Attach the tool rack to the cabinet.
Put the pendant spacer [2] onto the storage cabinet.
Put the pendant [1] onto the spacer.
Put the shoulder screw [4] into the washer [3].
Attach the screw to the pendant.
Install the swivel bracket [5] to the top of the pendant.
Remove the pendant rear panel [1].
Unwind the cables.
Push the cables [2] into the pendant.
Set the main circuit breaker to the OFF position.
Tag and safety the main circuit breaker.
Caution: Use an electrostatic discharge strap when you touch electronic components.
Connect these cables:
  • USB cable [1] to J23
  • LVDS video data cable [2] to J6
  • Ethernet cable [3] to J18
  • Power cable [4] to J20
Set the main circuit breaker to the ON position.
Caution: Before you test the pendant, remove all shipping brackets . The shipping brackets could cause very bad damage when you press POWER UP/RESTART.
Do these tests of the pendant connections:
Press [POWER ON].
If no display shows, make sure the pendant corrections are correct.
Press [RESET].
Press [POWER UP/RESTART].
Copy a test program from a USB device to the hard drive.
If an alarm shows, use the Alarm Help on the Service Home Page to find the cause.
Attach the rear cover [1] for the pendant.
Attach the cover [2] for the pendant swivel.
