Tool Release Piston - LED Pushbutton - Replacement - AD0699
Service Home How To Procedures Tool Release Piston - LED Pushbutton - Replacement - AD0699
Recently Updated Last updated: 03/17/2026
Revision 1
AD0699
Revision A - 03/2026
- Jump to Section - 1. Introduction 2. Replacement (3 steps) 3. Verification Back to Top
This procedure details how to install and wire a replacement LED or non-LED Tool Release Piston (TRP) Pushbutton.
This procedure applies to the following service kits:
  • 93-3798 PUSHBUTTON 50" TLRS REPLACEMENT
  • 93-3797 PUSHBUTTON 50" TLRS REPLACEMENT W/LED
  • 93-3796 PUSHBUTTON 78" TLRS REPLACEMENT
  • 93-3795 PUSHBUTTON 78" TLRS REPLACEMENT W/LED
NOTE: The machine in the images will most likely not reflect your machine. These images are for reference only, the steps will be the same for the machines listed below.
Machine compatibility:
  • 93-3798 is for UMC machines with 32-1215B
  • 93-3797 is for all other machines with 32-1215B
  • 93-3796 is for UMC, GM, VS, VR machines with 32-1216B
  • 93-3795 is for all other machines with 32-1216B
Replacement
Remove any paneling needed to gain access to the lower head cover.
Remove the lower head cover [1].
Disconnect the TRP cable [2] from the connector bracket [3] and the TRP button [4] from the lower head cover [1].
Updated
Install replacement TRP button into the lower head cover
Loop the hex nut through cable.
Loosely tighten the hex nut to hold the button in place.
Install the rubber button cover.
Push and hold the button in place with your finger and fully tighten the hex nut.
Note:  Over tightening the hex nut with a wrench will remove the seal
Make sure that cover is fully seated and that is in place.
Plug TRP button cable into connector bracket.
Reinstall lower head cover and all paneling.
Verification
LED TRP pushbuttons should light up red. Non-LED pushbuttons will not.
Verify that the pushbutton triggers the Tool Release Piston by removing and installing a tool into the spindle.
