Umbrella Tool Changer to Spindle - Alignment
Service Home How To Procedures Umbrella Tool Changer to Spindle - Alignment
4.1 Umbrella Tool Changer to Spindle - Alignment
Recently Updated Last updated: 08/12/2025
Revision A 08/2025
Umbrella Tool Changer to Spindle Alingment - Introduction
Before aligning the tool changer make sure you have Set Parameter 257 (Spindle Orientation Offset) and Set Parameter 64 (Z-Axis Tool Change Offset).
Remove Tool Changer Support Arm Cover
Push EMERGENCY STOP.
Find the cover [2] for the arm that supports the tool changer.
Remove the (8) socket head cap screws  [1] from the cover.
Note: Two of the screws are outside the machine enclosure.
Pull the cover out of the arm.
Loosen the four hex head bolts [3] that hold the arm to the column.
Remove only 1 of the 4 HHB that hold the arm to the column [4].
Align The Tool Changer
Release EMERGENCY STOP.
Verify no tools are in the spindle.
Go to MDI mode. Push ATC FWD.
Push FEED HOLD while the carousel moves to the spindle.
Use a pry bar [3] to move the tool changer.
Move the tool changer until the tool alignment key [2] aligns with the spindle dog [1].
Tighten the (4) hex head bolts [4] that hold the tool changer support arm to the column.
Torque the bolts to 80 Ft-lbs (356 N-m).
Push CYCLE START to complete the tool change.
Install the tool changer arm cover.
Install the (8) tool changer arm cover screws.
Do some tool changes and make sure the tool changer engages the tools evenly.
