WIPS Calibration - How to Create a WIPS Calibration Tool
Service Home How To Procedures WIPS Calibration - How to Create a WIPS Calibration Tool
Recently Updated Last updated: 12/21/2021
This procedure will show you how to make your own WIPS Calibration Tool.
A calibration tool is a tool of known length and diameter and is used for the Haas WIPS system and HTS400 presetter.
How To
Place an end mill or a gauge pin in an ER tool holder.
The end mill or gauge pin must be straight, true, and round.
Measure the diameter using a micrometer and take note of the value.
Note: Do NOT use tool holders with set screws such as a Weldon tool holder.
Place the tool in the spindle and check the runout.
Place a tenths indicator on the table and sweep the diameter, use a small hammer to true it in the holder.
Once finished, the runout should be .0000 inch.
Use the tenth's indicator and zero the indicator on the bottom of the tool as shown in [1].
On the pendent press [POSITION] and page over top the [OPERATOR] tab and type [Z] and press [ORIGIN] to zero out the z-axis position [2].
Jog the z-axis off the indicator and position it so that the indicator is zeroed out on the spindle face as shown in [1].
Use the value shown on the operator page [2] as the tool length.
Keep and record the tool measurement values and the tool can now be used as the calibration tool.
Note: If you are recalibrating the machine using a different tool, all offsets must be re-measured.
