Coolant VFD - Overview - RD0018
Service Home Coolant VFD - Overview - RD0018
20.1 Coolant VFD - Overview
Recently Updated Last updated: 10/16/2025
RD0018
Revision B - 09/2025
Coolant VFD - Introduction
This product is currently not field installable, documentation is for reference only.
The Variable Flow Coolant Pump option uses a variable frequency drive (VFD) to control the speed of our standard centrifugal coolant pump during operation. This allows control of the coolant flow and pressure directly from the program, via M code and P values.
NOTE: Not compatible with the High-Pressure Flood Coolant option (HIGH PRESSURE COOL).
The illustration shows where the VFD is located in the electrical cabinet.
  1. Coolant Pump VFD
  2. Shower Pump VFD (on some models)
Coolant VFD - Operation
The variable flow coolant option allows the user to operate the coolant pump at different speeds to increase or decrease the flow of coolant.
An optional P-Code can be specified along with an M08 to change the speed of the coolant pump.
  • M08 P0 = Low Pressure - The pump will operate at 50HZ speed.
  • M08 P1 = Normal Pressure - The pump will operate at 60HZ speed.
  • M08 P2 = High Pressure - The pump will operate at 80HZ speed.
NOTE: If no P-Code is specified, or the specified P-Code is out of range, then normal pressure will be used.
NOTE: If the machine is not equipped with a Variable Frequency Drive for the coolant pump, then the P-Code will have no effect.
