VF-5/40
PRE-INSTALLATION [GUIDE]
VF-5/40
    CNY ONLY
CNC Vertical Mill with 50" x 26" x 25" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 20 Tool Capacity
  • STEP-BY-STEP GUIDE
  • Layout Drawing
  • Lifting Instructions
  • Rotary Fit
  • Additional Resources
Pre-Installation Checklist
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient. However, heavy and complex machines, such as Large-Frame mills and UMCs, may require a 12" (300 mm) concrete foundation, to ensure accurate geometry.
Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
For best cutting performance, Haas recommends anchoring your machine. Click here to view anchoring kits for your machine
☑ Machine Placement
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
Read these instructions in their entirety before attempting to lift the machine.
WARNING:
IT IS IMPERATIVE THAT PREPARATION AND LIFTING OF THE MACHINE BE PERFORMED BY PROFESSIONAL RIGGERS. THESE INSTRUCTIONS ARE FOR REFERENCE PURPOSES ONLY.
IMPORTANT: Most – but not all* – Haas machines may be lifted by overhead crane for positioning and installation. Depending on the model, your new Haas machine may have built-in lifting provisions, or may require a lifting kit, available through your local Haas Factory Outlet (HFO), that includes required lifting brackets and hardware.
Refer to the lifting placard on the rear of the machine to locate all critical lifting points.
Specialized equipment is necessary to ensure that the machine is secure and level during lifting. When lifting the machine, slowly lift until all chains are taut, then lift the machine, making sure it stays balanced. Remove lifting brackets and hardware, if installed, before machine operation, unless otherwise noted. It is the customer’s responsibility to supply all chains and spreader bars required to properly lift the machine. Contact your local HFO for more information. Retain any supplied lifting brackets and hardware, and store them in a safe place for future use. Use only Haas-supplied lifting hardware, if required.
Refer to the lifting placard on the rear of the machine for model-specific lifting information. Attach the lifting bracket, if required, and chains as shown. Make sure that the chains do not contact the sheet metal enclosure or electrical cables. Note the use of spreader bars and lumber. Haas Automation, Inc., does not provide spreader bars or lumber.
*GR, GM, TL, CM, and CL models are not suitable for overhead lifting. They must be lifted by forklift.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 30.0 hp 22.4 kW
Domestic Pallet 168.0 in x 101.5 in x 109.0 in 427 cm x 258 cm x 277 cm
Export Pallet 164.0 in x 91.5 in x 101.0 in 417 cm x 233 cm x 257 cm
Weight 12700 lb 5761.0 kg
Domestic Pallet w/50+1 SMTC 168 in x 102 in x 122 in 427 cm x 260 cm x 310 cm
Export Pallet w/50+1 SMTC 164 in x 92 in x 101 in 417 cm x 233 cm x 257 cm
Weight w/50+1 SMTC 12700 lb 5761 kg
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine’s electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1 ,and CM-1.
Ground
Three-Phase Power
  • For Mini Mill Series machines, some options, such as Through-Spindle Coolant, require three-phase power.
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
Rotary Fit Chart
TH450 VF-5/40 POSITIVE FIT
HA2TS VF-5/40 POSITIVE FIT
HA5C VF-5/40 POSITIVE FIT
HA5C2 VF-5/40 POSITIVE FIT
HA5C3 VF-5/40 POSITIVE FIT
HA5C4 VF-5/40 POSITIVE FIT
HA5CS VF-5/40 POSITIVE FIT
HRC160 VF-5/40 POSITIVE FIT
HRC210 VF-5/40 POSITIVE FIT
HRT160 VF-5/40 POSITIVE FIT
HRT160-2 VF-5/40 POSITIVE FIT
HRT160SP VF-5/40 POSITIVE FIT
HRT160SS VF-5/40 POSITIVE FIT
HRT210 VF-5/40 POSITIVE FIT
HRT210-2 VF-5/40 POSITIVE FIT
HRT210M VF-5/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT210SP VF-5/40 POSITIVE FIT
HRT310 VF-5/40 POSITIVE FIT
HRT310SP VF-5/40 POSITIVE FIT
HRT450 VF-5/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRTA5 VF-5/40 POSITIVE FIT
HRTA6 VF-5/40 POSITIVE FIT
T5C VF-5/40 POSITIVE FIT
T5C2 VF-5/40 POSITIVE FIT
T5C3 VF-5/40 POSITIVE FIT
T5C4 VF-5/40 POSITIVE FIT
TR160 VF-5/40 POSITIVE FIT
TR160-2 VF-5/40 POSITIVE FIT
TR200Y VF-5/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TR210 VF-5/40 POSITIVE FIT
TR310 VF-5/40 POSITIVE FIT
TRT100 VF-5/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
TRT160 VF-5/40 POSITIVE FIT
TRT210 VF-5/40 POSITIVE FIT
TRT70 VF-5/40 POSITIVE FIT
HRT210HT VF-5/40 POSITIVE FIT
HRT210SS VF-5/40 POSITIVE FIT
TH240 VF-5/40 POSITIVE FIT
HA5C-T VF-5/40 POSITIVE FIT
HA5C3-T VF-5/40 POSITIVE FIT
HA5C4-T VF-5/40 POSITIVE FIT
TRT310 VF-5/40 POSITIVE FIT
HRT310SS VF-5/40 POSITIVE FIT
HA5C2-T VF-5/40 POSITIVE FIT
LT350 VF-5/40 POSITIVE FIT
LT260 VF-5/40 POSITIVE FIT
HRT210VM VF-5/40 POSITIVE FIT
HRT200HS VF-5/40 POSITIVE FIT
HQDA5 VF-5/40 POSITIVE FIT
HQDA6 VF-5/40 POSITIVE FIT
HRT210S VF-5/40 POSITIVE FIT
HDD255 VF-5/40 POSITIVE FIT
* If a rotary product is not listed, it is does not have a compatible fit with this mill.
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
