    2. Español - España
    3. Español - México
    6. Český
    7. Nederlands
    8. Magyar
    9. Polski
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
      • Frezarka do gniazd
      • Frezarki wspornikowe
      • Piły pionowe
      • Piła ukosowa
    • Obrabiarki kieszonkowe
      • Napędzane uchwyty tokarskie
      • Paleta narzędziowa
      • Torby na narzędzia
    2. Español - España
    3. Español - México
    6. Český
    7. Nederlands
    8. Magyar
    9. Polski
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
ST-35/35Y Cast Motor Mount/Plate Replacement
Serwis – Strona główna Procedura postępowania ST-35/35Y Cast Motor Mount/Plate Replacement
Recently Updated Last updated: 09/22/2022
- Przejdź do sekcji - 1. Introduction (11 kroki) 2. Removal (4 kroki) 3. Installation (7 kroki) Back to Top
This procedure tells how to replace Spindle Motor Mount Brace and Spindle Motor Mount Plate to the Cast Motor Mount and Cast Motor Plate
 You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
  Only authorized personnel with the proper training and certification should do this repair procedure.
  All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Tools Required:
  • 3/8" Stubby Hex Key
  •  Gates Sonic Meter
Machine Requirements:
Removal
  • Remove the door wiper and bumper assembly.
  • Remove the door roller guide from the top of the door.
  • Lift the bottom of the door up from the bottom door track. Pull the door away and out of the machine.
 Warning: The door is heavy. Get a second person to help you lift the door.
  • Remove the left front panel.
  • Remove all the left side panels.
  • Remove Motor Shrouds
  • Loosen the Motor Mount plates bolts
  • Remove Spindle Encoder mount and encoder
  • Loosen the belt tensioner
  • Remove the spindle belt from motor pulley
Note: Keep all encoder components to rebuild this motor with new motor plate
  • Remove Spindle Motor and Mounting Bars
  • Remove solid Steel Motor Plate from removed motor.
  • Install Cast Motor Plate onto the  motor. Refer to HAAS FASTENER TORQUE SPECIFICATIONS.
  • Install  the new encoder mount spacer and belt tension block.
  • Install Cast Motor Mount onto spindle housing
  • Torque the (x4) bolts. Refer to HAAS FASTENER TORQUE SPECIFICATIONS.
  • Secure the encoder cable and ground cable to the motor mount
  • Install motor assembly (with belt tension block) onto motor mount.
  • Tension the belt using the Gates Sonic Meter .
  • Install Encoder mount pate and Encoder.
  • Gap the encoder components
  • Perform the C-Axis - Engagement Offset procedure.
  • Install all motor shroud.
  • Install enclosure panels and test function of the machine.
