Spindle Belt Tension Specifications - Lathe - RD0065
Recently Updated Last updated: 06/23/2026
Lathe - Spindle Belt Tension Specifications
RD0065
Revision D - 06/2026
For information on how to use and setup the Gates Sonic Meter please view: Lathe Tension Adjustment. If your spindle has a non-contact encoder - be sure to reset the encoder gap AFTER resetting the belt tension. Changing the belt tension will change the encoder gap. If the gap is not reset it is possible the machine will generate alarms or worst case it will permanently damage the encoder ring or read head.
CL Series
MODEL WEIGHT WIDTH SPAN TENSION
CL-1 (Standard) 3.0 g/m 15 mm 187 mm 45 lbf (200 N)
CL-1 (High Torque) 3.0 g/m 15 mm 160 mm 45 lbf (200 N)
OL Series
OL-1 2.8 g/m 15 mm 200 mm
10 lbf (45 N)
SL Series (Using Torque Tool not Tension Meter)
MODEL TENSION
SL-10 (6K) 95 lbf (423 N)
SL-10BB 95 lbf (423 N)
SL-20 95 lbf (423 N)
SL-20BB 95 lbf (423 N)
SL-30 95 lbf (423 N)
SL-30BB 230 lbf (1023 N)
SL-40 230 lbf (1023 N)
SL-40BB 230 lbf (1023 N)
ST/DS Series - Rubber Belts
MODEL WEIGHT WIDTH SPAN TENSION (+/- 5 lbf (22N) )
ST-10/10Y 5.5 g/m 30 mm 322 mm 55 lbf (245 N)
ST-15/15Y (CHC) 4.7 g/m 21 mm 353 mm 49 lbf (217 N)
Three Belts: ST-15/20/30 5.5 g/m 20 mm 500 mm 40 lbf (178 N)
Two Belts: ST-15/20/30 DS-30Y (NGC) 5.5 g/m 20 mm 419 mm
62 lbf (275 N)
Single Belts: ST-15/20/30 DS-30Y (NGC) 4.7 g/m 36 mm 362 mm
75 lbf (334 N)
ST-30 (NGC) 5.5 g/m 20 mm 500 mm 65 lbf (289 N)
ST-30 (CHC) ST-30SS/30SSY 5.5 g/m 20 mm 485 mm 58 lbf (258 N)
ST-30BB 5.5 g/m 20 mm 483 mm 48 lbf (214 N)
ST-35/35Y 5.5 g/m 20 mm 459 mm 73 lbf (325 N)
ST-10/15/20/25/28 Sub-Spindle 3.9 g/m 15 mm 160 mm 46 lbf (205 N)
ST-30/35 Sub-Spindle 4.7 g/m 21 mm 182 mm 46 lbf (205 N)
DS-30Y(NGC) Sub-Spindle 4.5 g/m 21 mm 227 mm 100 lbf (445 N)
ST-40/40L/40BB/40BBXP 5.5 g/m 36 mm 549 mm 72 lbf (320 N)
ST-40XP 5.5 g/m 36 mm 576 mm 72 lbf (320 N)
ST-45 5.5 g/m 36 mm 549 mm 96 lbf (427 N)
ST-45L 5.5 g/m 36 mm 549 mm 96 lbf (427 N)
ST-50/55 4.7 g/m 36 mm 782 mm 93 lbf (414 N)
ST/DS Series - Polyurethane & HNBR Belts
Single Belt: ST-10/15/20/25/28/30/35/DS-30Y 4.7 g/m 36 mm 362 mm 75 lbf (334 N)
Two Belt: ST-20/25/28/30/35/DS-30Y 4.7 g/m 21 mm 384 mm 75 lbf (334 N)
62 lbf (275 N)
75 lbf (334 N)
ST-10/15/20/25/28 Sub-Spindle 3.5 g/m 15 mm 160 mm 80 lbf (356 N)
SB Series
Model Weight Width Span Tension (+/- 5 LBF (22N) )
SB-28/L/Y 4.7 g/m 36 mm 426 mm 150 lbf (667 N)
SB-35/L/Y 4.7 g/m 36 mm 426 mm 150 lbf (667 N)
SB-28Y & SB-35Y with Gearbox 4.7 g/m 36 mm 426 mm 150 lbf (667 N)
DS Series (CHC)
DS-30/30Y/30SS/30SSY (Main Spindle) 5.5 g/m 20 mm 500 mm 58 lbf (258 N)
DS-30/30Y/30SS/30SSY (Sub-Spindle) 5.5 g/m 20 mm 256 mm 114 lbf (507 N)
TL Series
TL-1/2 5.5 g/m 20 mm 545 mm 65 lbf (289 N)
TL-3 5.5 g/m 30 mm 572 mm 165 lbf (734 N)
TL-3B 4.7 g/m 21 817 mm 130 lbf (578 N)
TL-3HT 5.8 g/m 30 mm 610 mm 75 lbf (334 N)
TL-15 2.4 g/m 9.5 mm 160 mm 95 lbf (423 N)
TL-15BB 3.2 g/m 12.7 mm 249 mm 95 lbf (423 N)
TL-25 3.2 g/m 12.7 mm 249 mm 95 lbf (423 N)
TL-25BB 3.2 g/m 12.7 mm 344 mm 95 lbf (423 N)
