Single-Stage Pump (SINGLE STG CLT PUMP)
Product Image
GET QUOTE
Single-Stage Coolant Pump
    CNY ONLY
Reliable flood coolant delivery
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This single-impeller coolant pump provides reliable flow and pressure for the flood coolant systems on many Haas machines.
  • Reliable flow and pressure
  • 1 hp (0.75 kW) pump
  • Single impeller pump
  SAE Metric
Power 1 hp 0.75 kW
Flow Rate 60Hz 13 gpm @ 30 psi 49 L/min @ 2.1 bar
Pressure 60Hz (outlet) 30 psi 2.1 bar
Pressure 60Hz (spindle) 18 psi 1.2 bar
Deadhead Pressure 60Hz 35 psi 2.4 bar
Flow Rate 50Hz 11 gpm @ 20 psi 42 L/min @ 1.4 bar
Pressure 50Hz (outlet) 20 psi 1.4 bar
Pressure 50Hz (spindle) 12 psi 0.8 bar
Deadhead Pressure 50Hz 25 psi 1.7 bar
SERVICE DOCUMENTS
Need More Information?
