Cobot Stand, Fixed 30" (CBT STAND-FIXED 30)
Product Image
GET QUOTE
Cobot Stand, 30" Fixed Height
    CNY ONLY
Sturdy support for your cobot
  • Option Info
  • Specs
OVERVIEW
AVAILABLE ON THESE MACHINES
This sturdy tubular steel stand elevates your Haas cobot 30" (762 mm) above the floor to provide additional reach, depending on your application. The top mounting plate has multiple bolt-hole patterns to accept all Haas cobots.
  • 30" (762 mm) fixed height
  • Top mounting plate accepts all Haas cobots
  • Base plate has leveling screws for easy adjustment
  • Heavy-duty square tube/sheet metal construction
Top Plate and Base Plate Dimensions
Download 3D Model
SERVICE DOCUMENTS
Type Pedestal
Robot Series HC5 (5kg x 800mm), HC10 (10kg x 1000mm), HC15 (15kg x 1300mm)
Material Steel
[a] Dimension 10.551 in \ 268.0 mm
[b] Dimension 8.976 in \ 228.0 mm
[c] Dimension 9.449 in \ 240.0 mm
[d] Dimension 8.465 in \ 215.0 mm
[OAL] Overall Length 11.8 in \ 300.0 mm
[OAW] Overall Width 11.8 in \ 300.0 mm
[OAH] Overall Height 30.0 in \ 762.0 mm
Weight 87.3 lb \ 39.6 kg
Need More Information?
