UMC - B-Axis and C-Axis Intersection Adjustment
B Axis to C Axis Intersection Adjustment
For a machine with a Classic Haas Control change:
  • Parameter 151:20 (B-axis CHK TRAVL LIM) to 0.
  • Parameter 1314 (ROTARY AXIS CENTER DEVIATION IN X) to 0.
For a machine with a Next Generation Control change:
  • Parameter 6.021 (B-axis CHK TRAVL LIM) to FALSE.
  • Setting 254 (5-Axis Rotary Center Distance) to 0.
Push [ZERO RETURN]. Then push [ALL].
Jog the B-axis to -90°.
Note: The rotary positions are for reference only.
Put an indicator [1] on top of the alignment bar.
Jog in the Y-axis to find the high point.
Set the indicator to 0.
Jog across the alignment bar in the X-axis [2].
Jog the B-axis to adjust the alignment bar parallel to the X plane.
Jog the Y-axis to 0.
Caution: Make sure the indicator assembly is clear of the B-axis movement.
 Caution: Do not move the Z-axis.
Jog the B-axis to +90°.
Jog the Y-axis [1] to find the high point on the alignment bar.
Note: Do not set the indicator to 0.
Jog across the alignment bar in the X-axis.
Jog the B-axis to adjust the alignment bar parallel [2] to the X plane.
When the alignment bar is parallel to the X plane, the indicator reading is the change needed in the Z-Axis (∆Z=indicator reading).
Record the value shown on the indicator. In this example the indicator now shows 0.0015". ∆Z is 0.0015".
Do these calculations to get the value for CHC Parameter 1314 or NGC Setting 254. (In this example the difference in readings for the B-C intersection (∆Z) is 0.0015".):
  • ∆Z / 2 x 10,000 = CHC Parameter 1314 / NGC Setting 254
  • 0.0015 / 2 = 0.00075
  • Round down to 4 decimal places: 0.00075 = 0.0007 (NGC Setting 254)
  • 0.0007 x 10,000 = 7 (CHC Parameter 1314)
Set Parameter CHC Parameter 1314 (Rotary Axes Center Deviation in X) or NGC Setting 254 (5-Axis Rotary Center Distance), to the calculated value.
In this example, set parameter CHC Parameter 1314 to 7 or NGC Setting 254 to 0.0007.
Cycle the power to save CHC Parameter 1314 or NGC Setting 254.
Repeat Steps 1-3 to verify that the value for ∆Z is less than 0.0002" (0.005 mm).
Jog the B-Axis to the home position.
Set Parameter 151:20 (B-Axis CK Travel Limit) to 1.
Make sure the MRZP offsets are correct.
Calibrate WIPS per Wireless Intuitive Probe System (WIPS) - Calibration.
Complete an inspection report. Refer to UMC-750 Inspection Report.
