Broken Tool Detection - A62 Processor and PFDM PCB Replacement - AD0708
Service Home How To Procedures Broken Tool Detection - A62 Processor and PFDM PCB Replacement - AD0708
Recently Updated Last updated: 11/01/2023
Broken Tool Detection - A62 Processor and BTD A62 PFDM PCB Replacement
AD0708
This procedure will show how to replace the A62 processor and BTD A62 PFDM board of the Broken Tool Detection system inside the machine's control cabinet.
This procedure should apply to the follow service kits:
  • 93-3815 SVC KIT BTD A62
  • 93-4199 SVC KIT A62, BTD NO BRKT
NOTE: Use service kit 93-3815 for machines that do not have an enclosure on the main processor and use a bracket [1] to mount the BTD PCB (machines built before 02/25/2024). Use service kit 93-4199 for machines that have an enclosure on the main processor, the BTD PCB will bolt directly onto the enclosure (machines built after 02/25/2024 with main processor P/N 32-4267 or 32-4269).
Replacement
Disconnect all cables connected to the BTD A62 PFDM PCB [1] and the A62 processor [2].
Remove the BTD A62 PFDM PCB [1] from on top of the A62 processor [2].
Remove the A62 processor [2] from on top of the mounting plate [3].
Install the new A62 processor [2] on top of mounting plate [3].
 IMPORTANT: There is no mounting plate [3] needed for machines built after 02/25/2024 with the enclosed Main controller. The A62 processor [2] is located directly on Main controller.
Install the new BTD A62 PFDM PCB [1] on top of the A62 processor [2].
Connect the BTD camera cable 79-0159 into the USB adapter 74-2003 [1] that connects into the USB port on the A62 processor.
Connect both LED lights to the +12V LED power cable 33-1228 [2] that goes into J3 on the BTD A62 PFDM.
Make sure that the A62 processor power cable 33-1256 [3] is connected from J26 on the A62 processor to J4 on the BTD A62 PFDM.
Connect the BTD A62 PFDM cable 33-1227 [4] from J2 on the BTD A62 PFDM to J3 on the MAINCON. This cable also has a pigtail that connects to P20 on the PSUP.
Connect the communication cable 79-0158 [5] from the mico USB B port on the A62 processor to the USB port J8 on the MAINCON.
IMPORTANT: Make sure to insert the translator cable into the lower USB port J8 on the MAINCOM.
