Chip Separator Filter Replacement - AD0818
Service Home How To Procedures Chip Separator Filter Replacement - AD0818
22.3 Chip separator Filter Element Replacement
Recently Updated Last updated: 10/23/2024
Chip Separator - Filter Element Replacement
AD0818
This procedure will show you how to replace the filter in your chip separator.
This Document Applies to the following Service Kits:
  • 93-4865 CHIP SEPARATOR SERVICE KIT (Available on 12/24)
Required tools :
  • 3/16" Hex bit
  • Torque Wrench
  • Silicone grease
Machine Compatibility :
  • All VMCs and HMCs
Note : It is recommended to use the Haas Fastener Torque Specifications
Replacement
Press [POWER OFF] to power down the machine and inspect the pressure gauge [1] to ensure that the pressure reading is at 0 psi.
Open the ball valve [1] at the bottom of the chip separator to release all metal chips and debris into a container below to be disposed of properly.
Remove the (8) 1/4-20 bolts [1] from the top cap [2] to access the filter element.
Note : The hoses can stay attached to the top manifold and placed to the side.
Remove and replace the following components :
  • Sealing o-ring [1]
  • Filtering mesh element [2]
  • Silicone gasket [3]
Note : Clean the inside of the filter housing before installing the replacement components.
Note : Lubricate the sealing o-ring [1] with a light coat of silicone grease to prevent excessive friction during re-assembly.
Re-install the top cap and torque in a star pattern for even clamping.
Note : Some components are hidden in this illustration for clarity purposes.
