CL-1 - Bar Pusher - Spud Coupler Replacement
Service Home How To Procedures CL-1 - Bar Pusher - Spud Coupler Replacement
Recently Updated Last updated: 10/14/2021
AD0447
- Jump to Section - 1. Introduction 2. Remove Spud Coupler (2 steps) 3. Install New Spud Coupler (2 steps) Back to Top
This procedure show you how to replace the spud coupler on a CL-1 Bar Pusher.
This procedure applies to the following service kit:
  • 93-2992 CL BARPUSHER SPUD COUPLER SVC KIT
Remove Spud Coupler
Swing the bar pusher [1] clockwise.
Remove the bar collar halves [2].
Operate the bar pusher extend toggle switch [1] in small bursts until the bar pusher piston [2] extends out of the bar pusher tube.
Pull the bar pusher piston out of the bar pusher tube.
Use the vice with the aluminum jaws and pull the spud coupler [3] along with the polyurethane bushing [4] out of the bar pusher piston.
Add a drop of Ethyl Cyanoacrylate (Instant Glue) to the bottom of the polyurethane bushing. Fully insert the new polyurethane bushing [1] into the bore on the end of the bar pusher piston.
Mark the line on the bushing 0.1" (2.5mm) away from the face of the bar pusher piston.
Cut off the excess bushing material [2] parallel to the face of the bar pusher piston.
Clean the spud coupler and add a drop of Ethyl Cyanoacrylate (Instant Glue) to the bottom of the spud coupler. Fully insert the new spud coupler [3] into the bushing [4].
Note: There should be a 0.1" (2.5mm) gap between the spud coupler and the piston shaft.
IMPORTANT: Use the hose cutting tool to trim the bushing. Uneven edge will cause the bushing to wear prematurely.
Lightly grease the bar pusher piston with the RED-I grease and install it into the barpusher tube.
Verify the operation of the bar pusher .
