Compact APL Gas Spring - Replacement - AD0689
Service Home How To Procedures Compact APL Gas Spring - Replacement - AD0689
Recently Updated Last updated: 08/03/2023
AD0689
- Jump to Section - 1. Introduction 2. Replacement (4 steps) 3. Compact APL Gas Spring Configuration Update 4. Verification Back to Top
This procedure will show you how to replace the Gas Spring on a Compact APL.
This Document Applies to the following Service Kits:
  • 93-3780  C-APL OLD GAS SPRING REPLACEMENT KIT
Replacement
 NOTE: The gas spring cover is not shown for illustration purposes, it does not need to be removed.
Remove the Gas Spring [1] from ball stud [2] attached to the Gas Spring Mount [3].
Remove the Gas Spring [1] from ball stud [2] attached to the Angled Boom Mount [3].
Remove both ball studs [1] and ball stud spacers [2] from the Gas Spring Mount and Angled Boom Mount.
Keep screws [3] and ball studs [1].
Install the new ball stud spacers with the old ball studs and screws.
Install the new Gas Spring by attaching it to the ball stud on the Angled Boom Mount [1] then the ball stud on the Gas Spring Mount [2].
Turn on the machine.
Login to the HBC PORTAL.
Download the Compact APL Gas Spring option configuration patch files.
NOTE: The option files will appear on the configuration download page after the Compact APL Gas Spring service kit has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Verification
Run the Compact APL to verify that the Gas Spring was installed correctly and the patch files were uploaded correctly.
