Door Interlock - Euchner - Head - Replacement - AD0226
Service Home How To Procedures Door Interlock - Euchner - Head - Replacement - AD0226
Recently Updated Last updated: 12/08/2018
AD0226
Applies to machines built from: June, 2011
- Jump to Section - 1. Introduction 2. Replacement (2 steps) Back to Top
This procedure tells you how to replace the head on the door-interlock switch. This new head is a quick and easy replacement of the polycarbonate component, and will restore the interlock to full functionality. Over time, or after excessive force, the polycarbonate components inside the interlock can wear out. Do this procedure if the door interlock system has one of these symptoms:
  1. The door does not lock.
  2. The machine shows door fault alarms.
  3. The CE Interlock Switch Key (P/N 61-1013/61-1015/61-1016) does not go smoothly into the interlock head.
Machine Compatibility
Do this procedure for:
  • Machines that have a TP-series Euchner door-interlock system with a part number [1] that ends with a K, N, or M.
[A] 93-2309 QTY: 1 DOOR INTERLOCK, HEAD REPLACEMENT EUCHNER
Tools Required
T10 Torx Bit
Replacement
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the old interlock head [1] from the actuator body.
Install the new interlock HEAD [A].
Use a Torx driver to tighten the (4) screws [2]. Do not tighten the screws too much.
Test the interlock:
  • Close the doors.
  • Run the spindle at more than 1000 rpm.
  • The doors lock.
