Gearbox - Installation - 16DP-C - TL-4 - AD0393
Service Home How To Procedures Gearbox - Installation - 16DP-C - TL-4 - AD0393
Recently Updated Last updated: 12/01/2018
AD0393
- Jump to Section - 1. Introduction 2. Gearbox - Installation - 16DP-C - TL-4 (3 steps) Back to Top
This document tells you how to install 16DP-C gearbox [1] into the TL-4 Lathe.
Prepare the replacement gearbox:
 Note: For the machines built before 2014 the gearbox mounting bracket [1] needs to be modified to fit onto replacement gearbox. For details refer to STEP 3.
Remove the following parts from the old gearbox: spindle encoder assembly [2], spindle encoder mount [3], drive pulley support bracket [4], drive pulley support bearing [5] and gearbox mounting bracket [1].
Install the following parts onto the replacement gearbox: gearbox mounting bracket [1], spindle encoder mount [3] and spindle encoder assembly [2].
 Important: DO NOT install the drive pulley support bearing [5] and the drive pulley support bracket [4] onto replacement gearbox. Failure to do so will cause gearbox shifting issues.
Install the gearbox:
Using the pallet jack, slide the new gearbox halfway into the machine's base.
Route the motor power cables into the junction box [1].
Connect the rest of the cables at the connector bracket [2].
Connect air hose to the solenoid [3].
Slide the gearbox all the way into the base and install the 4 bolts [4].
Install the spindle drive belts [5] and the bolts [4].
With the gearbox unsupported brake the mounting bolts [4] loose and re-torque them. This will set the belt tension.
 Note: Refer to the Haas Fastener Torque Specifications.
Rework Pre-2014 gearbox mounting bracket:
You will need to enlarge the cutout [1] as shown in the picture to fit the bracket onto the replacement gearbox.
 Note: All dimensions are in inches.
