GM-2/5AX - Tall Chip Chute - Installation - AD0741
Service Home How To Procedures GM-2/5AX - Tall Chip Chute - Installation - AD0741
Recently Updated Last updated: 02/12/2024
AD0741
- Jump to Section - 1. Introduction 2. Installation (5 steps) Back to Top
This procedure will show you how to install the GM-2/5AX tall chip chute option.
This procedure applies to the following kit:
  • 93-1001029: CHIP CHUTE TALL RETROFIT KIT GM
This kit includes the following components:
  1. SPLASH GUARD
  2. TALL AUGER DISCHARGE CHUTE V-FLANGE COMPLETE
Remove the (5) bolts to remove the splash pan [1] from the casting
Note: Each chip chute cover shares (1) bolt [2] to install the splash pan [1] onto each chip chute cover. Remove bolt [2] to completely remove the splash pan [1].
Note: This image references the tall auger chip but it is the same steps to uninstall the short chip chute.
Use a ratchet extension [2] to loosen the nut.
Remove short chip chute [1] from the outlet tube on the base casting.
Verify that the O-ring [2] installed to the tall chip chute [1].
Verify that the V-flange clamp [3] is onto the tall chip chute. Make sure the nut on the clamp [4] points to the chip chute as shown.
Install tall chip chute provided in the kit onto the outlet tube on the base casting.
Turn the clamp to put the nut at the bottom of the tall chip chute. Make sure the nut points to your left.
Use a ratchet extension [2] to tighten the nut.
Important: Repeat steps 2-4 for the other chip chute.
Use the (5) bolts to install the splash pan [1] onto the base casting
Note: Each chip chute cover shares (1) bolt [2] to install the splash pan [1] onto each chip chute cover. Use bolt [2] to completely install the splash pan [1].
Operate the chip auger by pressing CHIP FWD on the pendant. Make sure the auger operates correctly.
