Haas Bar Feeder - Push Rod - Alignment
Service Home How To Procedures Haas Bar Feeder - Push Rod - Alignment
4.1 Push Rod Alignment
Recently Updated Last updated: 08/13/2025
AD0899
Revision A - 08/2025
This procedure shows how to align the push rod assembly in your Haas Barfeeder.
This Document Applies to the following Service Kits:
  • 93-30-11682A PUSH ROD ASSY 3/4" BARFEED
  • 93-30-11683 PUSH ROD ASSY 3/8" BARFEED
Machine Compatibility :
  •     All Haas Lathes equipped with Haas Barfeeder
Note : It is recommended to use the Haas Fastener Torque Specifications
Jog the V-Axis from the lathe [1] until it stops.
For CHC machines operate this code in MDI mode:
G105 Q6;
This lets you remove the push rod.
For NGC machines:
Press [RECOVER] to enter the Bar Feeder Recovery page. Press [F1] to unload the push rod.
Push [EMERGENCY STOP].
Use your hand to push down the holder [2] for the push rod.
Make sure the arm moves smoothly.
Make sure the distance [4] from the face of the pusher [3] to the face of the holder [2] is approximately 0.030" (1 mm). If the distance [4] is incorrect, refer to AXIS GRID OFFSET - NGC.
Install the push rod.
Operate this code in MDI mode:
G105 Q7;
This moves the push rod to the transfer table.
For NGC machines:
Press [RECOVER] to enter the Bar Feeder Recovery page. Press [F2] to load the push rod.
Loosen the two (2) screws [7] on the holder for the push rod and the two (2) screws [2] on the bushing holder [3] for the push rod.
Use your hand to push the pusher mechanism [1] toward the lathe until it is 2 inches from the bushing holder [3].
Tighten the screws for the bushing holder.
Push the pusher [1] until the dowel pins [5] connect to the push rod [6].
Make sure that the back plate [4] and the pusher mechanism do not touch.
Tighten the screws on the holder for the push rod.
 Note: The height of the bar feeder is possibly incorrect after the adjustment of the push rod. Refer to Haas Bar Feeder - Installation.
